6l swap wont start
#21
THe map will read somewhere in the neighborhood of 100 when the truck isnt running. Im not sure about fire, I suppose the coils are plugged in? I say that because I usually leave mine unplugged to turn it over a bit....
#22
well swapped crank and cam sensors with no change. sensors have power and so do coils just not firing for some reason. Everything seems good just no fire any recomondations on what to check? Coils are not getting a signal to fire
#25
just did the segment swap and about to go program it.
Gounds:
one on driver head on the back to fire wall
two in passanger side back of motor from wiring harness (Redid these two straight to the head)
one big cable on driver side front from block to battery
sound like I missed any? It was late amd I was tired just asking if there are anymore
Checked fuses in fuse box under hood for all ign fuses all good
Gounds:
#28
Might be a long shot but how about rpm signal from motor to gauge cluster my 96 wouldnt start cause of that don't know if the ls ones are wired the same but might help ya never know
CammedZ71
08-02-2015 01:44 AM
GreyChevy
07-07-2015 08:57 PM
