-   GMT 800 & Older GM General Discussion (https://www.performancetrucks.net/forums/gmt-800-older-gm-general-discussion-130/)
-   -   73-87 C10 trucks with 5" tach (https://www.performancetrucks.net/forums/gmt-800-older-gm-general-discussion-130/73-87-c10-trucks-5-tach-369279/)
ProStreet83C10 07-07-2006 10:08 PM
yeah i suppose...i wanna do a 383 with an 8-71 blower
nightrunner 07-08-2006 12:06 PM
that would be sweet especially with a butterfly scoop sticking through the hood :devil:
cbrich 07-08-2006 05:56 PM
This is the way I will be going. I will be adding a shift light where the factory headlight switch is and running an Autometer Recall Tach. The headlight switch will be moved to the column.
ProStreet83C10 07-08-2006 06:10 PM
Originally Posted by nightrunner
bette off to swap ina 400 turbo and be done with it
why would a run a tubo 400 when that takes more HP to run than a turbo 350 lol
nightrunner 07-08-2006 06:34 PM
if you dont do much more to your motor ok... well i dont really know what a turbo 350 will handle but i know a 400 turbo will handle almost anything stock
and it doesnt take hp to run a transmission u just have more parasitic loss in some more than others but i got what you were saying
the point i was making was the 700r4 is crap and will play out and is not worth modifying
cbrich 07-08-2006 06:44 PM
He is correct in almost everyway, a TH400 can handle any stock engine, the parasitic loss in a TH400 can be corrected with billet clutch drums, keep in mind they are very expensive. The only thing a 700r4 is good for is a boat anchor :jest: , but this is my opinion.
A TH350 will work but you will need a shift kit, good quality clutches, and the biggest cooler you can use; hell this is a must for any tranny.
nightrunner 07-08-2006 06:48 PM
the 87 gmc that i had had a 700r4 and i was just limping along on it when i wrecked the damn truck and this was on a 90k mile 305 tbi all stock with very high pegleg rear gears adn fluid changed when it was supposed to
ProStreet83C10 07-08-2006 06:58 PM
mine has seemed to hold up well for me so far...
nightrunner 07-08-2006 07:09 PM
it may do that for you but when it does break it will cost you
ProStreet83C10 07-08-2006 07:57 PM
lol ok, lets get back on topic......5" tachs
