75,000 miles maintenance
what do u guys do on a 75,000 mile maintenace? i already did my spark plugs, spark plug wires, oil change, fuel filter, belt change and i checked my brakes and i'm still good with those and i know i need to flush the tranny fluid. did i miss anything?
I just did my maintenace on my truck, I did the fuel filter, air filter, oil change, tranny flush, lube the front end, oil filter, plugs, wires, PCV valve, and flushed the cooling system. I also checked the brakes like you did and changed my belt. Thats what I did, any body else think of anything me and angelofdeath need to do?
Originally Posted by SnakeOiler
Have you changed your rear diff fluid lately?
whats the PCV valve? i don't think i checked that. so i guess that and tranny flush and rear diff fluid. "02bigblock" lubed the front end. what front end? sorry guys i don't know all my stuff. lol!
PT's Slowest Truck
Don't forget your coolant flush if you haven't done that yet either...
You can use one of those hand pumps used to pump gear oil into a trans or rear end to suck the fluid out of the power steering pump resevoir. You then replace the fluid with some new stuff. You can also flush out the old brake fluid out of your calipers and brake lines. You'd be surprised how much trash build up in the fluid over the years and 75K or a 100K of driving. Guys with manual trans can also flush the old fluid out of their master and slave cylinder as well. 75K is a good time to do this.
RedDeadG8
26
12-01-2015 11:32 AM
Noah Burns
09-07-2015 05:50 PM
BennyB
08-01-2015 08:48 AM
