9" spec tire on a 9.5" rim?
Tire manufacture accepted range is a 9" wide rim. Has anyone put a 9" manufacture range wide tire on a 9.5" rim and had any problems.
This is what Im talking about http://www.nittotire.com/#index.tire.nt420s.sizes
Look at the size 255/50/18 look under approved rim it say's 7.0-(8.0)-9.0 These should be the approved rim width sizes right? So 9.0 would be a approved max 9.0".
11 Second Hall Moniter
On a 9.5 inch wide wheel, it is best to have at least a 275 wide tire. The size you mentioned could be installed on that wheel, and, for most consumers, there would probably never be any problem. But the manufacturer IS trying to protect itself from people like us, who have alot higher torque than normal, and use it regularly. With excessive torque and an improper setup, the risk of tire failure at the bead is significantly higher, and blowouts can happen if the tires are not inspected for damage regularly. I usually see these types of tire problems on chipped diesels, running the wrong setup for custom wheels and tires, but we are not immune. I hope this makes sense.
For the other published specs (section width, tread width, etc.), an 8.0" rim was used (this is the number in parentheses).
luisalmighty09
08-20-2015 11:35 PM
thewrx
08-12-2015 08:28 PM
gcsd3742
07-06-2015 05:22 PM
