99-02 4 high mod
Old 03-26-2007, 08:54 PM
brent5631's Avatar
Default 99-02 4 high mod
alright guys i have spent the last hour looking through old threads and searching but still haven't found a true answer. i have a 99 silverado and would like to do the 4 high mod and maybe add the drl's when in high. but i would like to do it without cutting any wires.
Is it even possible to do?
I know about cutting the yellow wire and grounding but can i just jumper a few of the relays?
and can someone tell me exactly which prongs they are. i would like to do the mod but dont really want to hack up the wiring,
Thanks guys
great site by the way
Old 03-26-2007, 09:12 PM
VicRed's Avatar
I did mine the snipped and grounded yellow wire approach. Has worked great for the last 5 years.
Old 03-26-2007, 11:34 PM
ridnlow's Avatar
Old 03-26-2007, 11:36 PM
Tootall's Avatar
yep, ground out your low beams . . . meaning your ground wire on your low beam is not always "grounded" you'll have to cut the ground, and "ground it" to the core support, or some bare metal
Old 03-26-2007, 11:51 PM
blake2kz71's Avatar
can you give some more details? this might be a good sticky
Old 03-27-2007, 08:47 AM
Tootall's Avatar
pull off your head lamps, and do not touch the bulbs. There's two wires going into each of the plugs for the low beams, you need to ground one of those. It's either black or brown, I can't remember. . . I'll check later
Old 03-27-2007, 12:19 PM
brent5631's Avatar
yeah ive heard of this. its the yellow wire by the way.
but was wondering if anyone knew how to do it without cutting anything.
i dont really like the idea of a cuts and splices in wiring.
thanks guys
Old 03-27-2007, 01:14 PM
Tootall's Avatar
you can use some diodes, but I've yet to try it
Old 03-27-2007, 03:00 PM
Thanks guys
What the fu#k is a 4 High mod?
Old 03-27-2007, 03:06 PM
Tootall's Avatar
when you hit your hi beams . . . . what does it do, it goes from the outside lamps to the inside lamps. . . . shutting off the outers
The 4 high mod makes it to where all 4 are lit when you have the high beams on.
So if you go out right now and hold back your blinker changer, right before it makes that click noise, you'll notice that it lights up all 4's, the above, makes it that way with out you having to hold them down.
Quick Reply: 99-02 4 high mod
