99-02 4 high mod
Originally Posted by Tootall
pull off your head lamps, and do not touch the bulbs. There's two wires going into each of the plugs for the low beams, you need to ground one of those. It's either black or brown, I can't remember. . . I'll check later
Let me get this straight...
Yellow is the ground to the lows. Cut one ground, for only one headlight, or cut the ground for both lows, (the yellow on both low lights), and ground it /them to the body, and thats it?
Cut both grounds for both low beam headlights, and "ground them," 24-7. The grounds that come off the plugs, NOT the ground that goes back to the fuse box, tape that sucker off.
Originally Posted by brent5631
alright i went ahead and just cut the wires since i guess thats the only way to do it. but it took like five minutes and was super easy.
Originally Posted by blake2kz71
i hope this is all thats required b/c i have piaa high and low beam and i definately dont want to blow $30 a piece bulbs.
I have the same bulbs . . . you're going to wish that you did this since day one . . . you're going to like it, Ground it to the frame or engine block if you're really worried
so just cut the yellow wire coming straight off the bulb connector and ground it then do the same for the other side? sorry i know i sound dumb but im not wanting any surprises with this. so which end of the yellow wire do you ground? connector end or the other
