ABS and BRAKE light coming on all the time. have searched. Need help ASAP
Ok guys here is the scoop. I bought the truck about a month ago and 3 weeks ago both the ABS and BRAKE lights would come on together during driving. If I turn the truck off and turn it back on all is well. It was happening once every few days and with no regularity. Now its worse, comes on every time i drive the truck. OBD2 scanner shows no codes.
I have read several service bulletins that refer to a loose ground, I went through the driver side frame rail and tightned all the bolts it didnt help. Fluid level is good and I just flushed all of the fluid the other day.
I am running out of ideas and I have to tow a heavy trailer with all my stuff in it to Austin Monday. I dont want to drive down 35 with no ABS much less tow.
TIA,
Maksim
TIA,
Maksim
I have an ELMscan tool. It is showing no codes stored or pending. Do I have to go to the dealer for diagnostic as I would rather not pay stupid amounts of money for them to hook up a computer.
Had the same problem. It is the ABS module. You can get a new one for like $900 or take it off and send it to ABSfixer. They will repair it for like $120. Just go to there website for all the info.
Maksim
Hmm. Well it seems that either:
a. its a simple issue like faulty plug or dirty sensors
b. its the ABS module.
Only one of these things can be fixed in time for my trip, guess this weekend I am going to check out the module closely, and pull all the wheels to clean/check sensors. Fortunatly those are easy to test, also probably a good time to repack all the grease fittings in the front end.
