AC clutch wont engage
#21
Your system has a orifice tube, not an expansion valve. The high and low schrader valves are replaceable. The large low side fitting that looks like a small black ball inside is all one piece. You will need a special socket to remove it. Pliers can be used but it will tear up the aluminum. Replace the high and low and get it recharged.
#22
I have a gauge for that
This recharging business is getting expensive
I have a valve stem remover and tightened it a little since ive read that it sometimes loosens up and leaks. Im hoping that fixes it.
thanks for the help
thanks for the help
Lthompson
09-21-2015 05:34 PM
