AC Delco PF 59 to PF 46 ????
Old 03-02-2006, 08:02 AM
GREGGO's Avatar
Default AC Delco PF 59 to PF 46 ????
When did GM cange the PF59 to a PF46 for the oil filter on the trucks? That short little 46 filter is a joke. I understand they will no longer be making the PF59. I just ran out of my stock and went to get some new ones and found this out.
Old 03-02-2006, 08:23 AM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
PF 62 is what it changed too I believe. I have 3-4 in my tool box right now.
Old 03-02-2006, 08:53 AM
TG02Z71's Avatar
All this fun stuff is being discussed here too.
https://www.performancetrucks.net/fo...d.php?t=359414
Old 03-02-2006, 10:09 AM
zippy's Avatar
that changed happened sometime last year. the 59 wasn't replaced by the 62 (whatever that is). the 59 was replaced with the 46. you could use the 61 in it's place though.
Old 03-02-2006, 10:11 AM
1slow01Z71's Avatar
I ahve been using the 61/62 or whatever in its place with no problems whatsoever and the autoparts guy said it was the replacement for it. I will not put that little *** filter on there I will go to another brand before I do that.
Old 03-02-2006, 10:23 AM
zippy's Avatar
when that part number change went into effect we got alot of the same response here at work. we've had no problems to date with the oiling system. it sure doesn't look much like a "truck" type filter.
Old 03-02-2006, 10:24 AM
1slow01Z71's Avatar
Any insight as to why they went to a smaller "car" type filter?
Old 03-02-2006, 01:05 PM
TG02Z71's Avatar
Just guessing here but, probably because it will work on about 10 different vehicles compared to one or two now.
Old 03-02-2006, 02:04 PM
RoninsDenali's Avatar
I posted this in the other oil discussion thread, but its kinda buried on the 3rd or 4th page i forget which one exactly...
So, Alternatives to the PF-59
K&N, HP-2006 (PF-59 x-ref)
K&N, HP 1007 (PF-46 x-ref)
Mobil 1, M1-206
Wix, 51522
AC, UPF-44 (ACD's Ultra-Premium 46)
AC, PF-61 (Although listed, it has no anti-drainback valve but the same dimensions as the PF-59)
Old 03-02-2006, 02:25 PM
ranwalk's Avatar
It did switch to the pf46. Same filter that they have allways been using on the Fbodies and Corvettes. It may be smaller, but i'm sure if it's good enough for a vette it is plenty good enough for the truck engines. I may be switching to a K&N though, have heard good things about thier oil filters.
Quick Reply: AC Delco PF 59 to PF 46 ????
