AC freon leak?
#22
Before you go and do a bunch of work, why don't you get some pressures and post them up? The pressures will help diagnose the problem. A leak test would be good too.
I agree that the orifice tube should have been replaced with the new compressor. The accumulator / drier is usually replaced whenever the system is opened, too. However, if you replace the orifice tube but your problem is actually a leak on the new compressor, you're going to be back to square one next week, and have to spend even more money on freon.
Test for leaks and check your pressures. Post up your results and you will get some better recommendations on how to solve the problem right the first time.
#24
Originally Posted by Nick™
orifice tube removal tool??? what ever happened to a pair of needle nose pliers? worked fine on my 95 S-10
#25
Originally Posted by 1SlowHoe
Dont know what the oriice screen is so I will have to say it wasnt replaced. The compressor was a complete unit so if it's internal to the compressor it should be good.
ITS IN THE TUBE COMING OFF THE ACCUMULATOR TANK... GOING TO THE CONDENSER. RIGHT WHERE THAT NUT CONNECTS THE 2 LINES TOGETHER, THATS WHERE ITS AT.... SHOULD BE BETWEEN THE ACCUM BOTTLE AND THE SERVICE VALVE
#26
Spent all day on this stupid thing.
Short version:
Both the high side and low side service ports were leaking. Replaced the ball valve on the high side and then the %@!* low side needle valve popped as I pulled the freon machine hose off.
Anyway, I replaced the rubber O rings on the conpressor connections as well. I guess I will know in a few days if it is all holding.
Oh yea, pressure was 44 on the low and 220 on the high.
Short version:
#27
Short version:
Short version:
