AC not cooling
AC not cooling
The AC in my 2001 Chevy is not cooling. I put my gauges on it and it has 135psi static pressure at 90 degrees outdoor temperature. When the compressor is engaged the low side is 30-40psi and the high side climbed to 400psi before I shut off the system. I assume the high pressure switch is not working, but this does not explain why the system is not cooling.
I have already replaced the orifice tube and accumulator.
What the hell is going on?
Yes, I pulled 28 inches of mercury and held it for 30 minutes before I recharged the system. I keep my high and low pressure lines on my gauges pressurized and I purged the fill line before I added refrigerant.
First off the high pressure switch will not turn off the compressor until the high side pressure exceeds 420 psi. I attached a diagnostic sheet for the AC system when the low pressure is within spec and the high side pressure is too high.
carid
10-01-2015 09:22 AM
Wrecker 426
09-30-2015 09:39 PM
carid
09-10-2015 09:07 AM
