AC quit workin, need help.
Old 08-19-2007 | 02:11 PM
  #21
COLDZ71's Avatar
Originally Posted by nightrunner
yes with everything back together, replacing cabin air filters is a 10min. max job, depending on how har dit is to get to the screws holding on the heater box cover. if you dont have a heater box cover, its a 1.5-2 min. job, very easy
Cool, its starting to go together tonight then.
Old 08-19-2007 | 02:25 PM
  #22
Derek @ EDO's Avatar
FormerVendor
FUCCCCK, my AC is doing the same ******* thing! theres no way im doing all this ****.
anyway of diagnosing to be sure that it is the evaporator?
Old 08-19-2007 | 04:58 PM
  #23
dewmanshu's Avatar
Moderately Differentiated
have someone put the sniffer under your dash.
Old 08-19-2007 | 05:44 PM
  #24
COLDZ71's Avatar
When you have a shop fill the ac system with dye, check the evaporator drain on the firewall. It is right under the condenser. That is the only way for the dye to make it out if the evaporator is leaking. Definetilly take it to a shop to diagnoss the problem. And I HIGHLY recommend having them replace the evaporator (if that is what it is) if you can afford it.
thewrx
10-06-2015 11:59 AM
Wrecker 426
09-30-2015 10:39 PM
jtphelps289
09-30-2015 10:26 PM
SWINGRRRR
09-03-2015 08:49 PM
