ac smells like shitt???????
From: TEXAS: h'vill, smallest, boringest town u could ever dream of
i have a 2000 gmc swb singlecab, when the ac is on it smells like ****, its only when its on if its off and i have the windows down its smells fine, or when i just get in it in the morning it dosnt stink till i turn the ac on. whats the problem??????????????
have you ever changed the cabin air filter?
The evap core drain could be clogged. If the drain is clogged the moisture will build up in the case and will mildew causing the **** smell. The drain comes out on the firewall in the engine bay below the drier bottle. Sometimes it is hard to see so it might be easier to spot it from under the truck.
just look down a few threads...it was just discussed last week...
https://www.performancetrucks.net/fo...d.php?t=446435
Does it smell like rotten meat (animals/children), **** (****), or like a swamp (mildew in the evaporator)? The first two could be from mice in the evap, or somebody hated the former owner.
