Adding TPMS to 03+ Silverado
Your truck must already have remote key-less entry, as far as I know, for this to work. The key-less entry and TPMS are controlled through the passenger side door module. What you need is a PDM from a tahoe/yukon/escalade that already has TPMS, and the TPMS sensors. Swap the new PDM in the truck, perform the key-less remote relearn and the TPMS sensor relearn, and you are done!
Here is the factory PDM from my 2004
Here is the PDM I ordered from eBay. Notice how it says w/ TPM
TPMS sensors
This will now appear when you turn the ignition on
Scrolling through the DIC will bring you here
To perform the key-less remote relearn, follow these steps.
2004 Chevrolet Silverado - Free Keyless Remote Fob Entry programming instructions, procedures for all automotive vehicles
To perform the TPMS relearn, follow these steps.
tire pressure monitor (TPM) reset after rotation
TPMS sensors
Safety. If I let someone else drive my truck and a tire goes low the light will come on. I know what a low tire looks like but does your wife/daughter/girlfriend? Plus TPMS didn't come factory on my 2004, so it was cool that I was able to add it.
Added the new PDM, programmed the sensors to the truck, haven't set the pressures yet....
Anyone know how to get the TPMS to display in the DIC? I've pressed dang near every button on the steering wheel to get the to show, so far nothing.
I believe I've identified what exactly I need to get the specific tire pressures to show, my gauge cluster is not dual digital. What I mean by that is my cluster does not have digital PRNDL, the letters on printed onto my cluster backing, with a small selector light beneath each one of them.
To get the system to work (granted I have all the components required, including the RPO for steering wheel controls), all I need is this:
https://www.summitracing.com/parts/rnb-599-301
Girlfriend has a truck with a dual digital gauge cluster, I've going to try hers out in my truck first before I submit the purchase.
As far as the TPMS delete, in my truck, all I have todo is swap my PDM out for a non-TPMS model. Instantly deletes TPMS.
Last edited by tom_cassidy; 08-22-2016 at 11:40 AM. Reason: Read previous post incorrectly
Boombastic
08-05-2015 11:38 AM
