air still is not blowing hard
Old 08-23-2006 | 09:23 PM
ClayB's Avatar
but seriously.... the blower motor like yelo said.. or possibly the a/c controls in the dash..
TexCrew's Avatar
Originally Posted by Yelo
He means the AIR CONDITIONING is not blowing very hard with the fan on full, he's changed the cabin air filter and it didn't improve the situation.
I'd lean towards it being a weak blower motor...they're located under the dash in the passenger cabin and are kind of a PITA to change
my bud has an 05 1500hd..one day he turned his a/c on in a big hurry. now his a/c blows no harder than #4..his #5 is out.
Old 08-23-2006 | 09:48 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by BlackGMC
The air conditioning has a filter?
They discontinued the a/c filter after 02 or something like that....
As for the air not blowing hard, I'd think either the blower motor is weak, or possibly a blend door is stuck not allowing the air to flow in a concentrated path through the ducts that you have it set on. Check and see if air is dribbling out under the dash or through the defroster vents. I also remember an old TSB about a sealing problem with one of the HVAC ducts, don't remember the specifics though
Old 08-28-2006 | 08:52 AM
2k4tahoe's Avatar
ok so i was driving friday and all the sudden it kicked up and started blowing hard and then after some time it went back down. it did sound like some was coming out the defroster.
Old 08-28-2006 | 10:18 PM
Bowtie70SS's Avatar
His problem is the connector where it plugs onto the blower motor resistor under the passenger side of the dash. The connector melts at the #5 pin, and it typically takes out the resistor too. I had to replace the resistor and harness plug on my 03 SS , I "found" one in my toolbox when I got home from the junkyard.
Dave
Texas5.3_1251
03-05-2016 09:10 PM
chopperloco
09-28-2015 09:40 AM
TrickTurbo
09-23-2015 09:41 PM
MA$TER_E
09-09-2015 04:14 PM
