Alt. Charging issues w/ UD Pulley
The one I posted is cheaper...
But at least you get the idea now.
Also, if it is low rpm (idle)related, then the smaller alternator pulley will probably help. If it's all the time, it is likely something else.
I don't know about the belt length. But it's going to need to be shorter than stock for sure. I'd wrap a string around all the pulleys to get a starting point for length.
Try the pulley first. If that doesn't take care of it, then you may need to step up to a higher output alternator.
MA$TER_E
09-09-2015 04:14 PM
05GMC4.8
08-07-2015 10:55 PM
