Alternator B+ Wire Idea...
Old 10-31-2007, 09:29 PM
southern_chevy's Avatar
**** on my 04 GMC at idle with the a/c on it will not run my converter for my laptop, and starts to kinda surge.
Old 10-31-2007, 09:50 PM
truckmann's Avatar
Originally Posted by regency
so on a 145 amp alt. you would need a 145 or 150 amp fuse
Well not necessarily. The fuse is there to protect the wire from overheating and/or melting. So the size of the fuse is dependent upon what size and length of wire you are going to use.
Read here for some good info.
http://www.the12volt.com/installbay/...ize~PN~0~TPN~1
And here for wire size info.
http://www.the12volt.com/info/recwirsz.asp
Power & Ground Cable Specs
Size(ga)--- (amps)
1/0----------350
2------------225
4------------150
8------------100
10------------60
12------------40
14------------25
16------------15
Old 11-01-2007, 01:05 AM
allenmehrer's Avatar
does anyone have the details to this problem? i'd like to know more
Old 11-11-2007, 10:53 AM
PT's Slowest Truck
budhayes3's Avatar
Well, I gave it a shot...got a second B+ fusible link from GMPartsDirect and wired it in yesterday. A little grinding to the red box with a dremel and some wire loom and you can't even tell. (sorry no pics, left the digi camera with the wife and only had a little daylight to work with anyway).
I figure that having the extra wire will allow for more current flow and need a larger "fuse" on that ciruit, so hopefully the dual fusible links can handle the load and not smoke...if they do, I'll just upgrade to a bigger fused wire.
First thing I noticed, the factory voltmeter seems to be reading a tick higher than before (haven't checked it with my own meter yet), and the guage and headlights don't dip/dim as badly as before with the defroster on when the compressor and e-fans engauge. There's still a dip in volts when it hits, but it isn't as drastic. I think I'm going to wire in another relay and switch to disable the positive lead for the a/c fan relay when it isn't necessary (like when it's 30* out and the defroster is on lol).
I've only driven it about 10 miles so far, so I'll just keep my eyes on it and I guess time will tell
Old 11-12-2007, 09:09 AM
OnyxSilveradoSS's Avatar
so what are you using for the ground upgrade??? from where 2 where??? I wanted to run the engine ground to the alt bracket in the #2 I am using.
I have a pic of the wire I made, need to bpost it up
Old 11-12-2007, 10:51 AM
PT's Slowest Truck
budhayes3's Avatar
So far I've only done the B+ wire, eventually I'll probably do the Big3 with somewhere between 4 to 0 gauge....
Old 11-19-2007, 02:35 PM
here is mine fused.
Old 11-19-2007, 03:50 PM
Yogi Bear's Avatar
Very neat, Onyx! Where did you get the fuse and what is the rating on it?
Old 11-19-2007, 05:15 PM
jknox's Avatar
It looks like a Mega-fuse. Autozone sells a 175A. I use one on my setup, but I use a factory location in the electrical center for it.
Old 11-19-2007, 07:11 PM
truckmann's Avatar
Here is mine after I added this fuse holder.
http://cgi.ebay.com/In-Line-Waterpro...QQcmdZViewItem
Pictures suck best I could do in the dark with my old outdated camera.
Holder was about twice as big as I was expecting... O well used it anyway.
Here is where my ground ties in from the battery and then goes to one of the firewall lugs. Black wires on the acc. bracket above the PS pump. Just drilled and tapped a hole.
Here is my breaker fuse for the wire going to the amps.
Quick Reply: Alternator B+ Wire Idea...
