annoying exhaust sound
Mufflers - Street Mufflers - SPORT TRUCKS /SUV 5000 - 5441..3" center inlet 3" center outlet - SpinTech Performance Mufflers
the link is to the muffler im currently running now im thinkng of trying this moroso muffler but it would be 3inch insted of the 2 1/2
http://www.summitracing.com/parts/mo...FQee4Aod4AwAvQ
Your problem may also be that you have more exhaust pipe than you do engine. Putting a loud muffler on it (chambered for much higher exhaust volume) will only exacerbate the issue.
i dont know if its makes a difference but it only will make that sound when its under a load it wont do it just free reving the motor.
The cats smoothed the exhaust flow considerably, removing them basically is like removing a high temperature resonator. You get more flow and you get more sound.
Your engine isn't really pushing all that much exhaust through in stock configuration, though. The exhaust gases are slowing down (losing velocity) due to low supply and big pipe.
Well I think I got this figured out. 2 days ago I put on a magnaflow that's a single 2 1/2 in dual 2 1/2 out and it killed the popping sound. I guess ill have to have a dual exit muffler cause when I tried a single in single out magnaflow it still made that popping sound. I think I'm gona buy a spintech 6000 3 inch in with dual 2 1/2 out and see what happns.
Corvette454l88
09-01-2016 01:24 AM
V-seriesTech
07-28-2015 12:31 PM
