Another Vibration thread
Piss Pumps for Sale
Location: Moncton, New Brunswick, Canada, The True North Strong and Free!
1 Post
Well this has been going on since before I got the 35 inch toyo m/ts but its alot more obvious with the tires. Anyways between 65-75 mph I have a pretty harsh vibration not in the steering wheel but the whole truck, I can look over at the passenger seat and see it shaking, but its smooths out faster then 75 mph and isnt noticeable below 65. Also going over bumps I hear a clunk from my front end? I know I need a pitman arm and idler arm, so should I replace inner/outter tie rods and ball joints, maybe wheel bearings?
PT's Slowest Truck
My truck is a 99, and I used to have a vibration right around 60-65, that went away when I went faster also. After I lowered the truck the vibration went away, making me think that something was out of whack with the pinion angle from the factory, or at least, changing the pinion angle cured my problem. Might be something to look at.
As for your steering components, check them for play, if they're good and tight, you shouldn't need to replace them. If you want to do the tie rods due to mileage and for piece of mind that's your call. If your wheel bearings don't have any play and aren't making any noise, you shouldn't have to mess with them either.
I'd take your truck to a Tire Shop that has a Road Force Balancer. The road force balancer will balance the wheel and tire with pressure aplied that replicates actual road force conditions. The Balancer will also tell you if you have a bad tire or a warp or defect in the wheels. It's very handy on oversized tires or large diameter wheels. Mine has already paid for itself.
Tydriver
45
10-23-2015 09:19 PM
