Anybody does tile work?
TOTM: January 2007
What type of tile? Assuming ceramic. Use a wetsaw. I would avoid buying a saw unless your going to be doing this often. You will also want to buy the diagonal cutter to trim pieces around things which are not square.
550 square feet is a lot for a beginner to do in one day unless it is a perfectly flat smooth surface. Renting a saw may cost 40-50 per day. If i were you and were on a budget, I would lay your field one day and measure and mark all of the outside cuts. The next day rent the saw and make your cuts in 1/2 day and save some money.
Don't use premixed acrylic based mortar if its going outside. Use cement based mortar. Mix only half a 5 gallon buck it at a time if it is hot outside. Porbably want to use a 1/4 to 3/8 square notch trowel. Buy at least 3 buckets to clean the drill mixer bit, water, and your mix.
14 Second Truck Club
Stainless Works
04-10-2016 04:34 PM
atxlt
07-20-2015 11:06 PM
Nimoryan
07-05-2015 03:50 PM
