Anyone With a 03 - 06 w/Auto Climate Control
Old 03-30-2016 | 04:28 PM
03SuperSLADE's Avatar
Default Anyone With a 03 - 06 w/Auto Climate Control
I just changed my compressor and condenser and did a full flush and service on my A/C. I have put about 2.5 of the 3lbs of refrigerant in the system and only the rear ac is getting cold. The inlet to the front evaporator is sweating so i know its flowing.
I cannot recall if there is a snowflake on the control when the ac is on, can someone with the same controls let me know if they have a snowflake when the ac is on.
I don't know if i made a mistake by putting in one of those adjustable orfice tubes or if i am having a problem with my dampers.
I am going to do try the recalibrate but i am thinking i should have a snowflake showing when its on.
Thanks
Paul
Old 03-31-2016 | 04:51 AM
Suburbazine's Avatar
Yes, the head unit should show a snowflake on the display when AC is on. No snowflake (or blinking snowflake) means there is an issue with the AC control system (either pressure or electrical).
Old 03-31-2016 | 08:41 AM
Thank you for your reply, when i drove home last night the front ac started blowing cooler but i still didn't have a snowflake on my control.
I think i am going to try putting the balance of the refrigerant and see what happens. If it still doesn't seem right i guess i should switch out the VOV orfice tube for the stock static one.
Old 03-31-2016 | 01:09 PM
Wolftrk99's Avatar
First thing to check is whether or not the compressir iscoming on or not....
Old 03-31-2016 | 01:14 PM
Yes the compressor is cycling on and off.
91C1500sleeper
07-08-2016 10:54 AM
62nalide
14
04-03-2016 11:28 PM
02Sierra2500hd
03-26-2016 07:03 AM
GM1697
03-24-2016 10:43 PM
Quick Reply: Anyone With a 03 - 06 w/Auto Climate Control
