Anyone ever done an evaporator core?
Old 03-24-2008 | 02:34 AM
thunder550's Avatar
High on diesel fumes
Originally Posted by LowBlack99
Yeah they make tool for it kinda like a fuel line tool. I did the heater core in y dad's truck last year and it was a little rough but not to bad. Had to take the dash out also.
Thanks, I'll check it out tomorrow.
Originally Posted by 53RUSSELL
Sorry to change the subject. What wire did you plug you gauges into so when you turn your headlight the gauges light up? Looks like allot of fun.
Here's a pic of my dimmer/headlight switch harness. I spliced into the green wire...my gauge lights come on and dim with the dash lights.
Here's some better shots of the truck with a real camera. All of the interior parts are sitting in the bed.
Old 03-24-2008 | 03:21 AM
kbracing96's Avatar
Garage sell?? anyone need anything?
Old 03-24-2008 | 11:42 AM
53RUSSELL's Avatar
Thanks for pic of where you tap the gauges into the dimer switch. That looks like it sucks.
Old 03-24-2008 | 02:30 PM
jakebdb56's Avatar
Those pics remind me of pasadena
Looks like you're having some fun Thunder
Old 03-24-2008 | 04:42 PM
dewmanshu's Avatar
Moderately Differentiated
hahahaha I paid a mechanic to do mine for 200 bucks. WAAAAY WORTH IT!! FABOtaking the dash off.
Old 03-24-2008 | 04:49 PM
LowBlack99's Avatar
It's a job for sure!!! Once you get the dash loose you can swing it over towards the driver side and use some tiedowns to hold it while you work on the evap. core. It looks worse than it is, most people think it's real hard but I had the heater core out in less than 2 hours and put it back together the next day.
Old 03-24-2008 | 04:50 PM
thunder550's Avatar
Damn dewey! I thought my wiring was bad....looks like cake compared to yours!
Old 03-24-2008 | 04:51 PM
thunder550's Avatar
I was following the service manual for mine...I'm sure there are some shortcuts available and some stuff that I didn't need to take out that I did take out, but I don't see how I could have cut 4.5 hours down to 2 hours. Thanks for the tip on swinging the dash over. I've got my new evap and heater cores now, so I'll be working on it more tonight.
Old 03-24-2008 | 05:01 PM
LowBlack99's Avatar
I did alot of trim and DVD installs and such when I worked for GM so I allready knew what tools I needed and what had to come off beforehand so that helps. Experience goes a long way on projects like that. Cordless drill with a flex-extension and a magnetic 7mm and 10mm are a must for that job.
Old 03-24-2008 | 05:16 PM
thunder550's Avatar
Experience and power tools....that would do it I guess
