Anyone running a completely custom fuel system?
I have a gauge for that
With the stuff you currently have attach the pump directly to the outlet of the cell, straight to the regulator, have the regulator immediately return the excess to the cell, and the other end flow directly to the input on the fuel rail.
This has the advantage of keeping the fuel cooler, and great simplifies hose routing and the engine compartment routing. Disadvantage of having to pass all of the fuel through the regulator. Depending on your power goals and regulator, this may or may not be an issue.
What are your power goals and how do you plan to get there? (NA, nitrous, FI, etc.)
No, the name "returnless" is a bit deceiving. There is a return, its just in the tank so you never see it.
A lot of the drawings I'm seeing show a supply line from the pump to a "y". From the "y" two lines go to the back of the rails (one for each rail). On the front of the rail, again two lines come off (one for each rail) and go to each side of the regulator. Then from the regulator, a line returns back to the tank. Seems like a lot of un-needed braided line.q
The way you state to hook up the regulator, I am basically putting it inline directly after the pump? Correct? So I would need route a vacuum line all the way to the back where the regulator is? Will that be an issue? Also, I would connect the two rails at the front?
Yea, its a bit wasteful unless you absolutely need 2000hp worth of fuel. Im shooting for 1000 crank hp and am using single -8 feed to the back of one rail, crossover, then -8 to the reg from the end of the other rail.
That is correct. You dont have to have a vacuum reference, especially since you arent going FI, just make sure your tuner knows this.
Yea, its a bit wasteful unless you absolutely need 2000hp worth of fuel. Im shooting for 1000 crank hp and am using single -8 feed to the back of one rail, crossover, then -8 to the reg from the end of the other rail. And -6 or -8 whatever I have left over to run the return from the regulator to the tank. Does the return need to be lower than the regulator to go back to the tank, or will there be enough pressure bleed off to force it back to the tank?
As for the tune, that will be me as well. What will be different about it? Maybe flow rate vs. kpa? Or offset vs. volts vs. kpa? Under injector control in HP tuners. Seems like those are the only tables I can find that has to do with fuel and vacuum.
![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
D1SCSS
01-25-2016 10:14 PM
Nimoryan
07-05-2015 03:50 PM
