autozone torqflo fan clutch any good?
#21
11 Second Club
I just replaced a waterpump and decided I might as well replace the fan clutch also. I got a Hayden and I wish I would have left my stock one on there. This pos is loud all the damn time. Sounds like a fricken jet airplane taking off from stop lights. I cant stand it and am looking into the eFan setup. This is rediculous. It wil even do this in the morning when I first start it and its cool out (less than 60 degrees). My stock one has NEVER been this loud, even in 100 degree heat with the A/C on.
Mike
Mike
#22
I had a Napa HD clutch put on and so far so good, not loud at all really I don't notice it ever, my stock one would make the loud fan noise before it warmed up which I though was normal and this one doesn't even do that, very happy with it I idled it for 30 minutes never once twitched on the heat gauge, in 110° Texas everyday weather
#24
Generally when they go bad they don't hold excess pressure; they don't hold any pressure at all which causes the coolant to boil off and leave the cooling system for good. And boiling off in the heads is bad juju.
I think the GMT-800 cooling systems are 13-15PSI.
#25
A cap is a cheap replacement- don't worry about it, just replace it.
#26
The one you got is fine. As long as the pressure rating was between 13-15PSI and it screws down normally you're good.
The only real issue with the cheaper ones is that the seals will fail/rot sooner.
#27
