Is this bad?
Registered User
Did the intake and charger come all together or did you have to put it together,are the injecters seated all the way?
Does the noise go away on throttle or change pitch or tone?
I had a flex plate go out and one shop told me lifters,another told me injectors, flex plate was busted around five outta six bolts, but it changed tone and pitch under throttle,off throttle in gear and different tone in D or R.
sounds like the charger to me man...or the pully nothing i hear you should be worried bout...but if its lifters ur hearing try change the oil to something different
injectors are brand new came with the kit and already installed on the charger. I have always heard valvetrain noise more after the long tubes but thats because the material is thinner then stock manifolds. It just has me worried because its only on the passenger side.
when you say obvious you mean what? I have done all the work on my truck with the exception of the tuning and the paint but the internals of the engine and heads is something that is out of my experience level.
Sounds normal to me. Does it go away after it heats up fully or after driving for a while? I heard valve train noise when mine was stock (stock valve train that is). Mostly when started from cold though.
lukn4trbl355
10-21-2015 11:19 PM
