Bad gas mileage?
Bad gas mileage?
My 03' 8.1l is getting some really bad gas mileage. The 01' I had got 13+mpg. With a HIC it still got 12mpg. This 03' I have now is getting 9mpg.
I need to figure out what the hell is causing it to be so bad. Anyone have an idea where to start?
Both trucks are ECSB 4x4 3.73 gears. Same tires and wheels on the 03' that was on 01'. The 03' is 500lbs lighter then the 01' was.
Sense I bought the 03' I've done pugs, wires, o2s, rocker arms, and tuning. It had a K/N CAI on it and flowmaster mufflers.
Tuning didn't help the fuel mileage at all but the truck does run great.
Registered User
Hey Man, I have had the same issue with my 00 Sierra in the past. You said you changed plugs. What are they? If the are not ACDelco Uridiums I strongly suggest swaping them out. What grade fuel do you use? I used to run BP mid grade 89 oct. When I switched to Shell "V Power" my mileage went up by almost half. Believe it or don't, it's the truth. I would try these things first, you mite be surprised. Padre
I'd suggest changing mufflers since flowmaster is a chambered exhaust and a straight-thru muffler is less restrictive which could help a lot since your big block wants to breath. For example: Dynomax bullets or Magnaflow
Seriously, now...did it have a stock tune? How radical is that now?
Are u running same ratio rockers?
Did the other have a tonneau or some huge difference that you're forgetting or not currently using?
I'd think the Cd on the 03 would be slippier. I also thought the '03 would be heavier. Beyond that, I don't know.
