Baffaled with noise
Old 11-30-2012, 07:08 PM
  #31
phasemaster1's Avatar
Originally Posted by 1969x11
Sounds like you ate a lifter.I hope not
Had a few that rollers didnt look good. Cam also looked like crap so just tore it down.
Old 11-30-2012, 07:10 PM
  #32
Few lifter rollers looked like crap and so did the cam hardening fail somewhere. One piston had a small blemish. So tore it down.
Old 11-30-2012, 07:22 PM
  #33
When this happened to me it was the hardening on the lifter wheel that failed. Sent that **** through the bearings and ruined a 55,000mi 5.3. I gought a junkyard 5.3 and then the 4l60e died.... went with a 6.0/4l80e FTW!!!!
Old 11-30-2012, 07:25 PM
  #34
I caught mine early or wasent as bad. My bearings look good but going to make it a 5.7 now. Did your rollers have small pitts in them?
Old 12-01-2012, 06:48 AM
  #35
zero2sixT's Avatar
Threads like these are becoming more common. Sorry about your luck.
They cut the additives in engine oil. Supposedly when the oil is burned, it kills the catalytic converter(s). I had an email with a link to an article about it. I can't find it though.
You should run diesel engine oil. Or at least put some nickel/zinc additive in the oil you use.
lukn4trbl355
10-21-2015 11:19 PM
turbo6c3
10-05-2015 06:11 PM
Infernohoe
48
10-02-2015 10:25 PM
Velocity1
10-02-2015 08:01 AM
tim wellington
09-29-2015 10:17 PM
Quick Reply: Baffaled with noise
