Balancer puller Installer
i have a installer i made with some all thread, a piece of 1.25 d.o.m. and some washers welded to it .
i have the three jaw o.t.c. puller for the stock balancers
i also have an otc universal set with all the correct size bolts for the aftermarket balancers.
^^ yep i use a 3 jaw puller from oreillys part # 67021 to remove........ then heat up my pulley alittle to soften it. then use a piece of wood and hammer to somewhat get it on alittle further to i can run it on with the crankpulley bolt. Thats just temparily until i can find someone that sells a 120mm m16 bolt around here
