Bearing failure
Bearing failure
For those of you that wounder if you can use a four wheel drive bearing in a two wheel drive truck, the answer is no! I tried to tell my shop foreman that but he has done this for a long time, and know what he is doing. "It don't matter if it's two or four wheel there all the same." I just laughed and said ok. My self, I think it makes a difference. But I am an estimator what do I know.
Custm2500's Rude Friend
The 4x4 hubs on the 99-07 classic are not the same as a 2wd hub. They use the axle stub to keep the assemby together. Other years and other vehicals Maybe the same or similar in appearnce but on these they are not. Every time I have seen some one put a 4x4 hub on a 2WD it does basically the same thing.
Last tech I saw do this barely made it out of the drive way onto a busy street when this happened.
No we do not repack bearings, I work in a bodyshop and we got the knee assy. It came with the bearing already in it. That was the aftermath of a mile and a half of driving.
