Bearing failure
that's an old bearing...interesting that the steering knuckle you got came with the hub assembly, the used parts houses i've dealt with usually send the just the knuckle, either way i never assume used wear parts are good at all...lucky no more damage occurred!
11 Second Hall Moniter
The 4x4 hubs on the 99-07 classic are not the same as a 2wd hub. They use the axle stub to keep the assemby together. Other years and other vehicals Maybe the same or similar in appearnce but on these they are not. Every time I have seen some one put a 4x4 hub on a 2WD it does basically the same thing.
Last tech I saw do this barely made it out of the drive way onto a busy street when this happened.
Luckily(for the driver of the truck) the damage was minimal, and nobody got hurt!
BTW, my parts supplier(Carquest) lists 2 different part numbers. 515036 for 4x4, and 515054 for 2 wheel drive. NAPA shows 2 different part numbers as well. But I have seen applications where they do actually use the same part numbers, maybe it was GM? I don't remember right now...
I have always been told since these trucks came out, that the bearings are not inter changeable from 4 to 2 wheel drive. But that’s what happens when you work for know it alls. And we have to use what the insurance wants to stay on the programs. You call a reputable LKQ parts vendor, and one would assume that there parts catalog would tell them that it wouldn't work.
lukn4trbl355
10-21-2015 11:19 PM
