Belt Squeak
13 Second Truck Club
Because a squeaking belt means it's slipping. If it's slipping, the belt either needs to be replaced, or the tensioner is too weak, and needs to be replaced. Spraying stuff on it will degrade the rubber, and hasten the demise of the belt.
It's a band aid, not a fix.
well i would never tell someone to try something that i have never tried... and for years... this goes back to when engines had mutiple belts.. lol. better than throwing money at it and still have the same problem.. IMO. if you spray the belt and the noise goes away its the belt.. if it doesnt go away then we all know we have other problems. very easy..
I replace a crapload of a/c belts for this reason.
+1 on not spraying stuff on the belt, I have 110,000 on a 99 and still have both original belts. I also rarely replace them on the hundreds of higher mileage trucks,tahoes,yukons etc that come through the shop. A/C belt is another story, do several a week of those. A/C belt tensioners are common as well.
Thanks guys I wasn't planning on spraying anything on the belts My father in law told me to use belt conditioner and I told him no I know what chemicals do to rubber...I think I'll replace the belt tensioner first and go from there simply because it's the easiest/cheapest I think it's like 38 bucks I can deal with that rather than buyin a new water pump or alt just because of a noise and how hard is it to get to the ac belt while on jackstands I see it there but looks like a PITA thanks again guys
Do the A/C belt before you do anything else. If it hasn't been replaced, I'd put money that's where your squeak is coming from (and most people never replace it).
And it isn't hard to get to from the bottom if you pull off the front skid plate. You can get to the belt without removing it, but it's easier with it off.
PT's Slowest Truck
The AC belt isn't new also? That could be it too...
I would never spray anything on the belts, besides what's already been mentioned, it makes a mess. I have used valve lapping compound on squeaky belts, as the grit in the compound helps the belt to grip the pullies and stop the slip=squeak. As mentioned, the tensioner squeak is usually caused by old dry bearings.
(I did spray belts when I was younger before I knew better, and I have used a little squirt of some form of lube as a diagnostic tool to help pinpoint which belt is making the noise)
