Belt Squeak
#21
PT's Slowest Truck
But hey if it works for you, roll with it
#22
LOL, yea, I used to spray belts down, I've used "belt dressing" that comes in a can, and it usually worked temporarily but only masked the real problem...and made a mess out of the front of the engine and accessories. I do use spray at work to diagnose if a squeal is coming from a belt or somewhere else (I like white lithium grease in the can)...one quick squirt, and if the noise goes away, the problem is with the belt *usually*.
#24
mine has a slight squeak when its cold or damp out also. wasn't there before the coolant bypass mod but i dripped some coolant on the belt and now when its damp out i get the squeak. once the trucks up to normal temp it goes away?
belt or tensioner?
belt or tensioner?
SlvrSierra4.8
10-01-2015 09:39 PM
