Best way to reduce piston slap?
Old 01-28-2008, 09:19 PM
KeukaZ71's Avatar
Default Best way to reduce piston slap?
the last few winters the piston slap has been annoying me. any ways to reduce it?
Old 01-28-2008, 10:09 PM
Baltimore Whore
Mangled03gmc's Avatar
I don't think there is a way, unless you wanna rebuild your motor, with aftermarket pistons..
John
Old 01-29-2008, 04:59 AM
How do I change this text
Wilde Racing's Avatar
A hotter t-stat..
E-fans insted of clutched fan...
Old 01-29-2008, 12:44 PM
James B.'s Avatar
I recall some discussion from years ago about carbon deposits sounding like piston slap. If I remember right, Gen-III engine have a negative deck height meaning the pistons actually protrude into the head gasket area to minimize that piston-to-head clearance and reduce emissions. The TSB said carbon deposits in this area can be heard as something that sounds like piston slap. The solution is to run GM Top Engine Cleaner though it or Seafoam. These are harsh chemical cleaners and will probably foul the plugs. Oil change after treatment is mandatory.
If it's not carbon deposits there's nothing you can do. The short-skirts on the pistons and the pressed pins cause the pistons to rock excessively. You could always slap some Cummins badging on the fenders, no body will doubt it's a Diesel.
Old 01-29-2008, 01:10 PM
slowprocess's Avatar
Old 01-29-2008, 02:37 PM
KeukaZ71's Avatar
thanks for the suggestions
Old 01-29-2008, 09:42 PM
Originally Posted by slowprocess
LMAO
Old 01-29-2008, 09:51 PM
Mr. Obvious
nightrunner's Avatar
would a 20w50 oil help?
Old 01-30-2008, 08:15 AM
built408's Avatar
Use GM Top Engine Cleaner through a vacuum port and let it sit over night... Usually helps if not eliminates the noise... It's gonna smoke like a freight train once you start it up...
Old 01-30-2008, 08:17 AM
Wide Open's Avatar
Originally Posted by Wilde Racing
A hotter t-stat..
How does this help? Is it because the engine warms up quicker without the clutch fan?
Quick Reply: Best way to reduce piston slap?
