Brake hard line failure
Lost hydraulic brake power while driving. Hard line over the rear axle on passenger side cracked.
Does anyone know if just the line that goes from the T piece to the passenger caliper is available for sale? Thinking I can just replace that and go on. Thanks
The axle steel lines are not available, but all the front lines between the abs module and master cylinder, both front wheels and the main line along the frame are available in a kit through gm that are coated, theres a bulletin about it and it mentions fabricating the rear axle lines.... Some stores carry a pre cut and flared line that just needs to be bent into shape if you can match up fitting threadpitch and tube length...
I have a gauge for that
Not sure about the lines, but did/do you happen to have your exhaust pointed that way without going over the axle? At one point I didn't have an axle tailpipe piece so the exhaust just exited straight back from the muffler and pointed at the axle. I was at a dyno and it actually melted one of the straps (luckily when he was retightening and not during a pull), so I am wondering if you had that setup if that's what caused it to fail.
RJaxtheimer
10-10-2016 03:48 PM
Hillbilly Silverado
09-05-2016 08:29 PM
SLOPONY
25
09-01-2016 11:38 AM
