Brake options.... headache... alot of combos!!
Maybe with that any miles your looking to replace the MC as well? They arent terribly expensive or hard to replace. It will just make sure your whole system is back up to 100%. I'm sure some of your internal seals are leaking not allowing full pressure when applied......especially a '00 with 175k "used" miles......just a suggestion.
Im still lookin for SS lines... they arent too easy to find.
LS1Tech Whore
speaking of brakes,
my service master cylinder soon came on for a month back when I had 37,000 miles right after the warranty but the light went away. I never felt a difference tho. What could it have been.
IMO I would start with the rotors, pads and lines. My brakes sucked so bad they didn't even want to hold the truck easily idling in gear and were pulsing coming to a stop. I didn't want to spend anymore money than I had to at the time, so I just had the rotors turned and reused the pads that I had don't know how old they are or what brand since they were on the truck when I bought it still plenty of pad though. Then I put on SS lines and flushed the system with new fluid. It has been almost a year now and I am still happy with the improvement it made. Not to say it couldn't still be a little better, but it was a drastic improvement. Just saying I would start by either turning the rotors or getting new ones and see how that does before jumping in and replacing everything.
i'm running slotted/drilled rotors, hawk pads on stock calipers all around with earl's stainless lines. not great, but better than stock. its a truck...its gonna show signs of that from time to time.
I change my front pads about once a year and my rears every other year
I'm at 90k and the truck is 7 years old. You're on your first pads and I'm on my (5th and 3rd?) and it's time for another set in the rear right now and maybe the front too.
I'd like to hear what works for making them last longer and stop better w/o going bigger bc I have 16" wheels
I replaced my pads and rotors with SSBC's slotted rotor kit. It is part number SSB-A2351019 through Summit. should fit your application. I've had great success on my 04 Z71 ECSB, and great pad wearing characteristics. it slows this heavy truck quicker than stock.
I have never used EBC parts on a vehicle, heard good things though...
