Brake System Issues
Sweet, thanks man. After I replace the master, I will be doing this. What I don't understand is why bleeding the brakes helped with the issue? Maybe the vibration from the impact gun caused it to read correctly for a little while? I don't know, but I do remember having to do this to my other Silvy a while back. I'll let you know what the result is.
PT's Slowest Truck
Originally Posted by bigredexpress99
•Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in the General Information sub-section of the Service Manual.
•Disconnect both the front wheel speed sensor connectors at the frame and harness.
•Place a Digital Volt Meter (DVM) across the terminals of each wheel speed sensor connector.
•Rotate the wheel clockwise approximately one revolution per second. The minimum reading should be at least 350 ACmV's. If the reading is less than 350 ACmV's, remove the wheel speed sensor
PT's Slowest Truck
Just caught the second part of your question...yes, a sticking slider can act like a sticking caliper and cause a brake pull...and now that I think about it, a sticking/siezed caliper or slider pin could contribute to pre-mature ABS activation, as that wheel will be spinning at a different speed than the others when the brakes are applied and the EBCM will pick that up and activate the ABS.
SLOPONY
20
10-18-2016 06:05 AM
05GMC4.8
08-07-2015 09:55 PM
