A/C Issue Electrical
The clutch stopped engaging on the truck last month. So heres what ive tested so far.
1. Check system psi , its fine
2. Jump low pressure switch nothing...
3. Check all fuses. There good.
4. Jump the compressor with leads from the battery. Clutch engaged hmm!
5. Swap AC Relay with known working fuel pump relay. Nothing....
6. Ground out AC Relay pins. Clutch comes on. WTF!
7. I swaped hvac controls with a known working unit. Still didnt work
Could it be a bad spot in the pcm? Ive read its possible since it has the final say so on engaging the clutch.
Fastest D1 Procharged Truck
could very well be a blown compressor make sure it still spins freely all you need to do is we're the belt goes on the pulley can turn by hand your good if it docent most likely its toast
Mine worked when I jumped the relay, but would not work when turning the ac on from the control head. No 5v reference signal to the pressure sensor by the compressor, break in wires was about 6" back from the connector.
Ill double check. But I took all wire from compressor all the way up to fuses out of lume and inspected. They were fine. We are talking about the plug behind the compressor right.
