Cam or Convertor first
vette servo is easy to install.
258mm IF you dont plan to pull anything over 1000-1500 lbs imho. if you do go with a triple disc so you can lock it and have the extra insurance of not burning up the clutch band.
i did a 3200 on 3:42s and a stock 5.3 was way more fun than doing a motor swap with a cam but as far as the converter goes...base it upon future mods such as what cam you are thinking of running, nitrous, turbo, supercharger...every application takes a certain stall to get the best of both worlds.
Z06 cam is good for spray but mainly boost not N/A unless you want a Tame DD such as a 13.5+ truck and have very little time in tuning.
I prolly will go with a light cam nothing that won't hurt daily driving and something more on the low end this won't be built for racing unless some ricers are out
Lol Garrett... until about 3200-3600 rpm your truck drove just barely better than stock, and then it roared around then... could definitely hear and feel difference.
Everything I've read says converter first unless you're doing a baby cam... and even still a trailblazer I5 converter for 100 bucks is recommended to get you up to 2600 faster
The older equivalent is the V6 S-10 blazer DCLF TC. I run 1 behind my L31 and its much better than stock.
peace
Hog
