Can't figure out what's up with my 5.3...
2003 5.3 Tahoe, 225k, only a BB tune, airaid jr intake, oe wires, coils, Delco plugs. Tune up was 5k ago right before smog & passed extremely clean. I installed Bosch o2 sensors as well. Engine doesn't use oil. Intake gaskets done 25k ago. No issues.
A few weeks back, leaving work, the truck started fine & after a few minutes started missing. Not a dead miss but sounded lopey. It has a distinct change in sound/tone/miss when it goes from open loop to closed loop but the sounds & frequency of the misses are erratic.
Scanner showed random misfires on bank 1, #7 was missing more than #'s 1,3, & 5.
Sprayed carb cleaner around the intake...no change...
Pulled vacuum line off FPR...no leaks...
Swapped plugs between cylinders...no changes
Swapped wires between cylinders...no changes
Swapped coils between cylinders...no changes
I changed injectors on all 8 cylinders...no changes
Did a noid light test on all 8 injector wires...all good...
Compression check was ~175 on all 8 cylinders...
Variance between high & low was 6%...well within limits...
Leak down was good...
No bent pushrods or funny valvetrain movements...
Oil pressure good, no coolant missing...
Pulled the plugs...1&2 read a little rich
3,4,5,6 looked normal
7&8 read lean.
(5k ago when I switched plugs all 8 were perfect & probably didn't need changing.)
I have not checked fuel pressure yet...testing that Monday as I had to order a new tester.
I'm thinking my Bosch o2 sensors are having issues...I've read up about them. Any advice? I'm stumped & our mechanic at work has been buried so I've been trying to debug myself when I have a little time. Fuel pump is relatively new...60k miles. Still not discounting that it's crapping out though.
Cameron
7&8 read lean.
Cameron
Fuel press reg is common prob on high mile trucks but only probs i've had from a bad one is...hard starting, & when you punch it falls on its face like its running out of gas.. Dunno if that helps.
