THIS cant be happening to me
Old 03-13-2009, 02:35 PM
THE-HOE's Avatar
Default THIS cant be happening to me
So a little while ago i bought a worked up aluminum block 6.0 and everything has been great, until today. All of a sudden this morning my oil pressure is only 20lbs and it knocks. The oil level is up and the oil quality is good. Just low pressure and a knock. This motor only has 8000 miles on it, 8000 miles and its taking a **** on me. Im just so depressed. Does anyone know what the problem might be. Main bearings? i assumed if it was just an oil pump that it wouldnt knock. Everything, including oil pump and bearings were brand new when i bought it. I just needed to complain to someone, this is my only vehicle. So i guess the Bus is next.
Old 03-13-2009, 02:46 PM
GMCtrk's Avatar
I'm sorry to hear about this. I'm no mechanic but it doesn't sound good. I've seen your videos and I know you aren't easy on that LS2 though.
Old 03-13-2009, 06:38 PM
Banned
TexasPainter's Avatar
pull the pan off and check the bearings.
Old 03-13-2009, 06:47 PM
THE-HOE's Avatar
Yea, im not easy on it, but im actually not as hard on it as i was with the 5.3 but thanks for the support
Old 03-14-2009, 08:28 AM
PT's Slowest Truck
budhayes3's Avatar
**** man, sounds like you smoked a bearing
Old 03-14-2009, 08:37 AM
KySilverado's Avatar
When a pump fails usually all pressure is lost but never know. Drop in pressure does point to a bearing along with the knocking.
Sucks buddy. Unfortunately I read a lot about LSx style engines failing after a rebuild.... more so than other engine platforms. Makes me worry about doing my own build when the time comes.
Old 03-15-2009, 07:36 PM
goldcoast's Avatar
sounds like a pinched o ring on the oil pick up tube. might be wrong but it's a 2 buck chance
Old 03-15-2009, 07:40 PM
FormerVendor
Derek @ EDO's Avatar
Sure does!
Old 03-15-2009, 08:14 PM
phasemaster1's Avatar
Im with these guys...
Old 03-15-2009, 09:26 PM
hirdlej's Avatar
It only takes about 5PSI of oil to float a bearing at idle. If you have at least that much oil pressure at idle and it's still knocking I would be looking for something mechanical causing it, not an oil pump
Quick Reply: THIS cant be happening to me
