Can't program keyfob
I have an 06 silverado ext cab I purchased back in July no fobs just one key. It came from a tow recovery lot so didn't think much about it.
Tried to program using YouTube videos and write ups and from what i understand it is not going into program mode if it cycles the lock before you letoff the unlock button during the key cycle.
TLDR looks like im missing some relays under the dash could this be the cause?
I've swapped glove boxes for a console swap so I can't look at my spid sticker, but the passenger door has no keyhole. which should mean it has keyless entry.
So today I tried to look into fuses and noticed on the dash panels it lists what i think is relays for lock and unlock separately. None of those relays are present, and can't the driver door unlock the passenger door with a key turn? That also doesn't work. I was thinking unless it's a work truck remote entry was kind of standard by this time?
So I'm trouble shooting why it won't go Into program mode.
CashDudeHomie
10-28-2009 01:11 AM
