check engine flashing and a p0300
this is on the 2005 truck
apparently this misfire is the reason as to why my truck wont lock the TC. so im trying to figure out the problem.
i just (an hour ago) replaced the plugs(drivers side plugs were black), wires, and coils. with all brand new stuff. then i swapped MAFs with my 03 sierra. still had the code. then i sprayed carb cleaner around the intake to see if i had a intake leak. no change in RPMs or tone change.
i scanned the truck and it looks like bank 1 o2 is putting out around 20-30mv where bank 2 was 700-900mv bank 1 injector pulse was a lot higher then bank 2.
could any of these be causing problems or are they some of the effects of the problem(s).
tweeder
09-18-2015 11:02 PM
GMCtrk
38
08-09-2015 08:50 PM
bsgiffor
07-19-2015 11:14 AM
