Check Re-Calls & Service History Here
Old 06-18-2010, 11:04 AM
  #1051
Vinniety's Avatar
Originally Posted by Torque_Wrench
Het bro...thanks for the kudos. As long as I can help someone out, I'm happy. I know how it feels to have a problem and no one to help you....so..I try to do whatever I can to help everyone.
Here's your rundown.
VIN: 1GNEK13Z42R272153 Model: CK15706-2002 TAHOE 1/2 TON 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 60 - RETAIL - SOLD
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Product Safety Recall N050068 05068 FRONT WHEEL SPEED SENSOR CORROSION 09/22/2005 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677).
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: N XM Radio ID: XM Status: NA
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Bumper to Bumper Limited Warranty 04/30/2002 35 MI 04/30/2005 36,035 MI
Emission Limited Warranty 04/30/2002 35 MI 04/30/2005 50,035 MI
Emission Select State Component Lty Wty 04/30/2002 35 MI 04/30/2009 70,035 MI
Corrosion Limited Warranty 04/30/2002 35 MI 04/30/2008 100,035 MI
Emission Select Component Ltd Wty 04/30/2002 35 MI 04/30/2010 80,035 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
09/04/2007 202674 ZFAT----Field Action Recall V1410 - 05068 - Inspect Wheel Sensor (inc. cleaning) 51,014 MI
03/29/2004 139045 ZREG----Regular Vehicle Transaction B4181 - Cylinder, Front Door Lock - Left - R&R Or Replace 20,248 MI
03/29/2004 139045 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 20,248 MI
03/29/2004 139045 ZREG----Regular Vehicle Transaction C6871 - Driver Seat Cushion Cover Replacement 20,248 MI
03/29/2004 139045 ZREG----Regular Vehicle Transaction F3269 - Ventilator, Axle - Front - Replace 20,248 MI
03/29/2004 139045 ZREG----Regular Vehicle Transaction B4180 - Front Side Door Lock Cylinder Replacement 20,248 MI
01/22/2004 135550 ZREG----Regular Vehicle Transaction C7051 - Cover And/Or Pad, Front Seat Back Cushion - Left - R&R Or Replace 18,404 MI
01/22/2004 135550 ZREG----Regular Vehicle Transaction E7700 - Shaft, Steering Intermediate - Replace 18,404 MI
04/05/2002 A72153 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Thank You very much.
Vinniety is offline
Old 06-21-2010, 12:20 PM
  #1052
Registered User
4ws_4wd's Avatar
Would you mind checking the following VIN? Thanks in advance:
1GKGK26U03R194208
4ws_4wd is offline
Old 06-22-2010, 03:34 PM
  #1053
1GKGK26U03R194208
After a short bout with some Food Poisioning on Sunday and Yesterday...I have returned. Sorry about the wait time...here's your vehicle rundown.
VIN: 1GKGK26U03R194208 Model: TK25906-2003 GMC YUKON XL 2500 4WD
Order Type: 70 - RETAIL - STOCK
Product Safety Recall N030002 03002 MID-FRAME CROSS MEMBER TEAR 02/13/2003 Closed
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: EDXC10WX XM Status: Inactive
Emission Limited Warranty 12/21/2002 11 MI 12/21/2007 50,011 MI
Corrosion Limited Warranty 12/21/2002 11 MI 12/21/2008 100,011 MI
Special Coverage-07187 12/21/2002 11 MI 12/21/2009 80,011 MI
Bumper to Bumper Limited Warranty 12/21/2002 11 MI 12/21/2005 36,011 MI
Service Contract
06/22/2004 779816 ZREG----Regular Vehicle Transaction E3300 - Front Torsion Bar Adjustment 35,443 MI
06/22/2004 779816 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 35,443 MI
06/22/2004 779816 ZREG----Regular Vehicle Transaction L1228 - Fuel Tank Fuel Pump Module Replacement - Rear 35,443 MI
06/22/2004 779816 ZREG----Regular Vehicle Transaction D1323 - Motor And/Or Fan, Blower - A/C Condenser - R&R Or Replace 35,443 MI
06/22/2004 779816 ZREG----Regular Vehicle Transaction Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 35,443 MI
05/26/2004 773211 ZREG----Regular Vehicle Transaction D1180 - Switch, Pressure Cycling - Replace 33,939 MI
05/26/2004 773211 ZREG----Regular Vehicle Transaction Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 33,939 MI
02/24/2004 750438 ZFAT----Field Action Recall V0967 - 03002 - INSTALL FUEL TANK SHIELD 29,612 MI
02/24/2004 750438 ZREG----Regular Vehicle Transaction D0362 - Heater and Air Conditioning Control Replacement 29,612 MI
01/29/2004 745086 ZREG----Regular Vehicle Transaction B4151 - Outside Rearview Mirror Glass Replacement - Left Side 28,450 MI
01/29/2004 745086 ZREG----Regular Vehicle Transaction Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 28,450 MI
01/29/2004 745086 ZREG----Regular Vehicle Transaction D1810 - Air Inlet Valve Actuator Replacement 28,450 MI
12/22/2003 101364 ZREG----Regular Vehicle Transaction D1810 - Air Inlet Valve Actuator Replacement 24,585 MI
12/27/2002 011399 ZREG----Regular Vehicle Transaction N8521 - Transfer Case Shift Control Module Reprogramming with SPS 1,023 MI
12/11/2002 A94208 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Torque_Wrench is offline
Old 06-25-2010, 03:56 PM
  #1054
Registered User
racegirl04's Avatar
I was hoping you could check my VIN for me:
1GTHK29182E195002
It's a 2002 GMC 2500HD
Thank you so very much in advance!
racegirl04 is offline
Old 06-28-2010, 07:43 AM
  #1055
1GTHK29182E195002
Not a problem...here you go.
VIN: 1GTHK29182E195002 Model: TK25753-2002 SIERRA 2500 EXT 4WD
Order Type: 50 - FLEET
Customer Satisfaction Program N020050 02050 EMISSION LABEL VISIBILITY **IN EFFECT UNTIL JUNE 30, 2003** 12/14/2002 Closed
Customer Satisfaction Program N050546 05546 15,000 MILE - 24,000 KM FUEL FILTER CHANGE **IN EFFECT UNTIL SEPT. 30, 2006** 08/10/2005 Closed
Product Safety Recall N040007 04007 TAILGATE SUPPORT CABLE 09/17/2004 Closed
Branded Title
Warranty Block
Service Information
Vehicle has no current record of OnStar / XM Radio information.
Bumper to Bumper Limited Warranty 02/19/2002 64 MI 02/19/2005 36,064 MI
Special Coverage 07057 02/19/2002 64 MI 02/19/2012 200,064 MI
Special Coverage 04039 02/19/2002 64 MI 02/19/2009 200,064 MI
Corrosion Limited Warranty 02/19/2002 64 MI 02/19/2008 100,064 MI
Emission Select State Component Lty Wty 02/19/2002 64 MI 02/19/2009 70,064 MI
Emission Limited Warranty 02/19/2002 64 MI 02/19/2007 100,064 MI
Diesel Engine Ltd Wty with Deductible 02/19/2002 64 MI 02/19/2007 100,064 MI
Service Contract
09/26/2006 045427 ZREG----Regular Vehicle Transaction J3524 - Engine Coolant Heater Replacement 82,334 MI
03/20/2006 032638 ZSCT----Service Contracts F1670 - Seal, Hub Oil - Rear Axle - Right - Replace 73,639 MI
03/20/2006 032638 ZREG----Regular Vehicle Transaction J4760 - Plugs, Glow (Diesel) - Right - Replace 73,639 MI
01/11/2006 028054 ZREG----Regular Vehicle Transaction T5603 - 04039 - Replace all 8 Fuel Injectors - Refer to TSB 04-06-04-007F 69,275 MI
01/11/2006 028054 ZREG----Regular Vehicle Transaction J5955 - Pump, Fuel Injection (Diesel) - Replace 69,275 MI
01/11/2006 028054 ZREG----Regular Vehicle Transaction Z7903 - 3-DAY COURTESY TRANSPORTATION 69,275 MI
09/06/2005 019438 ZSCT----Service Contracts N2821 - Fuel System Relay Replacement 65,437 MI
09/06/2005 019438 ZFAT----Field Action Recall V1380 - 05546 - Replace Fuel Filter 65,437 MI
03/08/2005 006133 ZFAT----Field Action Recall V1242 - 04007 - Inspect and Replace Tailgate Support Cables inc. Hinge Replacement if Necessary 55,983 MI
06/25/2004 092723 ZREG----Regular Vehicle Transaction J5919 - Module, Direct Fuel Injection Driver (Diesel) - Replace 46,084 MI
06/24/2003 063607 ZREG----Regular Vehicle Transaction J3380 - Fan Blade Replacement 27,922 MI
06/24/2003 063607 ZREG----Regular Vehicle Transaction Z7903 - 3-DAY COURTESY TRANSPORTATION 27,922 MI
03/13/2003 055144 ZREG----Regular Vehicle Transaction N2827 - Powertrain System Relay Replacement 21,552 MI
01/29/2002 026534 ZREG----Regular Vehicle Transaction B4000 - Front Side Door Adjustment - Right Side 25 MI
01/29/2002 026534 ZREG----Regular Vehicle Transaction B9660 - Underhood Lamp Replacement 25 MI
01/29/2002 026534 ZREG----Regular Vehicle Transaction B5880 - Rod And/Or Latch, Tailgate Lock - R&R Or Replace 25 MI
01/10/2002 A95002 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Old 06-28-2010, 07:09 PM
  #1056
Jake Harsha's Avatar
1GCEK19T1XE120695
Thanks man! You rock!
Jake
Jake Harsha is offline
Old 06-28-2010, 11:53 PM
  #1057
Registered User
racegirl04's Avatar
Thank you so much!!! Much appreciated
Old 06-29-2010, 08:22 AM
  #1058
Originally Posted by Jake Harsha
1GCEK19T1XE120695
Jake
Ha,ha,...thanx....here you go. get those Field Actions completed!
VIN: 1GCEK19T1XE120695 Model: ZZUSV-1970
Order Type: N/A
Field Actions: 5 Open
Customer Satisfaction Program N000024 00024 FRONT BRAKE HOSE ABRASION 05/19/2000 Open
Noncompliance Recall N000045 00045 FRONT SAFETY BELT COMPLIANCE 09/13/2000 Open
Product Safety Recall N060019 06019 TAILGATE SUPPORT CABLE REPLACEMENT 04/03/2006 Open
Product Safety Recall N000093 00093 FRONT BRAKE PIPE CONTACT WITH BODY CROSS SILL 01/09/2001 Open
Product Safety Recall N050068 05068 FRONT WHEEL SPEED SENSOR CORROSION 09/22/2005 Open
Branded Title
Warranty Block
Service Information
Vehicle has no current record of applicable warranties.
Service Contract
Transaction History
Vehicle has no current record of transaction history.
Old 07-10-2010, 12:40 PM
  #1059
hawaiianstyle's Avatar
Default new truck
Hey Torque_Wrench, just purchased a new 2010 GMC Denali, can you run my VIN: 3GTRCXE26AG167350 Would like to know everything I can about my new purchase. Hopefully only good things!!!!
hawaiianstyle is offline
Old 07-10-2010, 10:05 PM
  #1060
jlwz71's Avatar
When you have time would you check my vin please. Thank you for your time.
1GCEK19T0XE145670
jlwz71 is offline
Quick Reply: Check Re-Calls & Service History Here
