Check Re-Calls & Service History Here
#1061
Hey Torque_Wrench, just purchased a new 2010 GMC Denali, can you run my VIN: 3GTRCXE26AG167350 Would like to know everything I can about my new purchase. Hopefully only good things!!!!
here is youer rundown
VIN: 3GTRCXE26AG167350 Model: TC10543-2010 SIERRA 1500 2WD SHORT BOX CREW CAB
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Vehicle has no current record of required field actions.
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Type Number Description Posted Date
EI PIE0089 DTCs P0335 or P0336 Set, Malfunction Indicator Lamp (MIL)/Check Engine Light On, Possible ExtendedEngine Crank or Crank/No Start 06/28/2010
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677).
OnStar Equipped: Y OnStar Status: Active
XM Equipped: Y XM Radio ID: ZY7242RM XM Status: Inactive
OnStar Vehicle Diagnostics: Y DMN Enabled: Y
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Bumper to Bumper Limited Warranty 06/30/2010 11 MI 06/30/2013 36,011 MI
Corrosion Limited Warranty 06/30/2010 11 MI 06/30/2016 100,011 MI
Emission Limited Warranty 06/30/2010 11 MI 06/30/2013 50,011 MI
Emission Select Component Ltd Wty 06/30/2010 11 MI 06/30/2018 80,011 MI
Emission Select State Component Lty Wty 06/30/2010 11 MI 06/30/2017 70,011 MI
Powertrain Limited Warranty 06/30/2010 11 MI 06/30/2015 100,011 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
01/18/2010 A67350 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
#1062
VIN: 1GCEK19T0XE145670 Model: ZZUSV-1970
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: N/A
Field Actions: 4 Open
Type Number Original Nbr Description Release Date Status
Customer Satisfaction Program N000024 00024 FRONT BRAKE HOSE ABRASION 05/19/2000 Open
Noncompliance Recall N000045 00045 FRONT SAFETY BELT COMPLIANCE 09/13/2000 Open
Product Safety Recall N060019 06019 TAILGATE SUPPORT CABLE REPLACEMENT 04/03/2006 Open
Product Safety Recall N000093 00093 FRONT BRAKE PIPE CONTACT WITH BODY CROSS SILL 01/09/2001 Open
Branded Title
Warranty Block
Service Information
Vehicle has no current record of outstanding service information.
Vehicle has no current record of OnStar / XM Radio information.
Vehicle has no current record of applicable warranties.
Service Contract
06/20/2001 101408 ZREG----Regular Vehicle Transaction B4051 - Link Or Spring, Front Door Hold Open - Left - Replace 17,329 MI
#1063
#1064
MASS seller approved
I just bought this truck used and would appreciate it if you could run it.
VIN:1GCGK13U27F148414
I dont think they did but im hoping there is something on the guage cluster. Its just asinine that the whole cluster has to be replaced to replace a bulb.
#1065
Thanks, but they put in the wrong mileage on the repair of my door check. I replaced it and I gave them the old door check back with mileage written down on a piece of paper. The local dealer has never touched my truck since I bought it new. I knew the service manager well at that time. Now the guys that work there resemble monkeys doing algebra. I know about the recalls and have checked all the areas that are listed. I have no problems. It has never been turned into GM. If (and that's a big if) I decide to sell it I will have the recalls officially done by a dealer 50 miles away. Strange but oh well its not important to me. Thanks for your time at work though. My local contact here quit. He even gave me the last set of esi dvd discs he had. Goes up to 2005 I think. Rarely use it though since I have AllData at work. Thanks for helping out.
#1066
could you please check this vin? tks.
1GTHK232X5F810245
1GTHK232X5F810245
Vehicle Information
VIN: 1GTHK232X5F810245 Model: TK25743-2005 SIERRA CREW CAB 4WD 3/4 TON
Order Type: 50 - FLEET
Product Safety Recall N050037 05037 SECOND ROW CENTER SAFETY BELT 07/14/2005 Closed
Branded Title
Warranty Block
Service Information
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: N XM Radio ID: XM Status: NA
OnStar Vehicle Diagnostics: N DMN Enabled: N
New Vehicle Limited Warranty 08/23/2004 26 KM 08/23/2007 60,026 KM
Emission Limited Warranty 08/23/2004 26 KM 08/23/2009 80,026 KM
Corrosion Limited Warranty 08/23/2004 26 KM 08/23/2010 160,026 KM
Diesel Engine Ltd Wty with Deductible 08/23/2004 26 KM 08/23/2009 160,026 KM
Service Contract
07/20/2007 297861 ZREG----Regular Vehicle Transaction Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 64,231 KM
07/20/2007 297861 ZREG----Regular Vehicle Transaction J6270 - Exhaust Gas Recirculation Valve Replacement 64,231 KM
05/07/2007 293388 ZREG----Regular Vehicle Transaction E7700 - Shaft, Steering Intermediate - Replace 52,999 KM
03/02/2007 289688 ZREG----Regular Vehicle Transaction Add Credit J0680 - Tensioner, Primary Accessory Drive - Replace 42,563 KM
03/02/2007 289688 ZREG----Regular Vehicle Transaction J0680 - Tensioner, Primary Accessory Drive - Replace 42,563 KM
05/04/2006 272242 ZREG----Regular Vehicle Transaction N6620 - Power and Grounds Distribution Wiring and/or Connector Repair or Replacement 24,378 KM
03/01/2006 268335 ZFAT----Field Action Recall V1382 - 05037 - Stitch Seat Loop Closed 22,229 KM
01/12/2006 227901 ZREG----Regular Vehicle Transaction R5126 - ON-STAR VIU/VCIM COMP RET TO AC/DELCO ESC 12,075 KM
01/11/2006 265504 ZREG----Regular Vehicle Transaction R5140 - Module, Vehicle Interface Unit VIU/VCIM - Replace 15,075 KM
09/19/2005 258690 ZREG----Regular Vehicle Transaction N0117 - Battery - Both - Replace 14,634 KM
09/06/2005 257949 ZREG----Regular Vehicle Transaction E9320 - Cover And/Or O Ring Seal, Steering Gear End - Replace 14,534 KM
08/26/2005 257426 ZREG----Regular Vehicle Transaction N6602 - Charging/Starting/Battery Wiring and/or Connector Repair or Replacement 13,316 KM
08/26/2005 257426 ZREG----Regular Vehicle Transaction J1000 - Pan And/Or Gasket, Oil - Replace 13,316 KM
04/06/2005 248585 ZREG----Regular Vehicle Transaction H0137 - Rear Brake Rotor Replacement - Both Sides 10,000 KM
04/06/2005 248585 ZREG----Regular Vehicle Transaction H0127 - Front Brake Rotor Replacement - Both Sides 10,000 KM
01/04/2005 243067 ZREG----Regular Vehicle Transaction N9995 - Customer Concern Not Duplicated - Electrical 4,500 KM
12/29/2004 242771 ZREG----Regular Vehicle Transaction H0121 - Rotor Assembly - Front - Left - Replace 4,011 KM
12/02/2004 241498 ZREG----Regular Vehicle Transaction Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 945 KM
12/02/2004 241498 ZREG----Regular Vehicle Transaction N6602 - Charging/Starting/Battery Wiring and/or Connector Repair or Replacement 945 KM
12/02/2004 241498 ZREG----Regular Vehicle Transaction N4800 - Body Control Module Replacement 945 KM
08/04/2004 A10245 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 KM
#1067
VIN: 1GCGK13U27F148414 Model: CK15743-2007 SILVERADO LS 1500HD CREW 4WD
Order Type: 60 - RETAIL - SOLD
Branded Title
Warranty Block
Service Information
SB SB10168 Free Agent Best Practices for HUMMER, Pontiac, Saab and Saturn Customers or Those Affected by Dealership Consolidation? 06/22/2010
Bumper to Bumper Limited Warranty 10/30/2006 20 MI 10/30/2009 36,020 MI
Emission Limited Warranty 10/30/2006 20 MI 10/30/2011 50,020 MI
Emission Select State Component Lty Wty 10/30/2006 20 MI 10/30/2013 70,020 MI
Corrosion Limited Warranty 10/30/2006 20 MI 10/30/2012 100,020 MI
Powertrain Limited Warranty 10/30/2006 20 MI 10/30/2011 100,020 MI
Service Contract
04/09/2010 772807 ZREG----Regular Vehicle Transaction J0100 - Manifold, Exhaust - Right Bank - Replace 90,480 MI
05/27/2009 289559 ZREG----Regular Vehicle Transaction F1440 - Output Shaft Seal Replacement - Right Side 74,849 MI
03/10/2009 285636 ZREG----Regular Vehicle Transaction J0750 - Seal, Timing Cover Oil - Replace 69,323 MI
12/11/2007 262897 ZREG----Regular Vehicle Transaction N0761 - Bulbs, Stop, Tail, And Turn Lamp (Left) - Replace 33,109 MI
12/11/2007 262897 ZREG----Regular Vehicle Transaction L2020 - Hanger And/Or Clamp, Exhaust System - Replace 33,109 MI
10/26/2006 242606 ZPDI----Pre-Delivery Inspection Z6998 - PDI Adds 20 MI
10/11/2006 A48414 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
#1068
#1069
#1070
Torque Wrench could you please run my vin 1GCEC19Z76Z268634 Thanks alot!
Everything else on par.
Vehicle Information
VIN: 1GCEC19Z76Z268634 Model: CC15753-2006 SILVERADO 1500 EXT 2WD
Field Actions: 1 Open
Service Update Bulletins N060162 06162 SERVICE UPDATE-INVENT/CUST VEHS E85 VFFS UPDATE REPGM ECM *EXPIRES 8YR/80K MI* 12/12/2006 Open
Branded Title
Warranty Block
Service Information
Emission Select Component Ltd Wty 05/01/2006 85 MI 05/01/2014 80,085 MI
Corrosion Limited Warranty 05/01/2006 85 MI 05/01/2012 100,085 MI
Bumper to Bumper Limited Warranty 05/01/2006 85 MI 05/01/2009 36,085 MI
Service Contract
04/30/2009 769721 ZREG----Regular Vehicle Transaction E7012 - Switch And/Or Control, Steering Wheel Mounted - Replace 35,512 MI
04/30/2009 769721 ZREG----Regular Vehicle Transaction B4521 - Rear Side Door Outside Handle Replacement - Left Side 35,512 MI
05/01/2007 364609 ZREG----Regular Vehicle Transaction K7121 - Pump, Transmission Oil - R&R Or Replace 14,214 MI
03/21/2006 A68634 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
