Check Re-Calls & Service History Here
#1081
thanks for the last one torque. i just found another d-max do you mind runnin it for me? thanks. 1GCHK23133F103251.
VIN: 1GCHK23133F103251 Model: CK25743-2003 SILVERADO CREW CAB 4WD 3/4 TON
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 60 - RETAIL - SOLD
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Customer Satisfaction Program N050546 05546 15,000 MILE - 24,000 KM FUEL FILTER CHANGE **IN EFFECT UNTIL SEPT. 30, 2006** 08/10/2005 Closed
Product Safety Recall N050037 05037 SECOND ROW CENTER SAFETY BELT 07/14/2005 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677).
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: N XM Radio ID: XM Status: NA
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
New Vehicle Limited Warranty 08/26/2002 53 KM 08/26/2005 60,053 KM
Special Coverage 07187 08/26/2002 53 KM 08/26/2009 112,053 KM
Emission Limited Warranty 08/26/2002 53 KM 08/26/2007 160,053 KM
Diesel Engine Ltd Wty with Deductible 08/26/2002 53 KM 08/26/2007 160,053 KM
Special Coverage 04039 08/26/2002 53 KM 08/26/2009 320,053 KM
Corrosion Limited Warranty 08/26/2002 53 KM 08/26/2008 160,053 KM
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
05/26/2008 338086 ZREG----Regular Vehicle Transaction T5686 - 07187 - Special Coverage Adjustment - Replace & Reprogram IPC (inc. Gauge Sweep Test) 140,573 KM
05/26/2008 687850 ZREG----Regular Vehicle Transaction T5680 - Instrument Cluster Assembly, GMT 800 Special Coverage Bulletin # 07187 140,573 KM
05/01/2006 119084 ZSCT----Service Contracts F1671 - Seal, Hub Oil - Rear Axle - Left - Replace 101,259 KM
03/14/2006 117234 ZSCT----Service Contracts N3860 - Windshield Washer Pump Replacement 99,048 KM
03/01/2006 116723 ZSCT----Service Contracts H2412 - Front Wheel Speed Sensor Replacement - Both Sides 97,691 KM
03/01/2006 116723 ZSCT----Service Contracts E8040 - Tie Rod, Inner - Right - Replace 97,691 KM
09/22/2005 110451 ZSCT----Service Contracts N3565 - Windshield Wiper Motor Cover Replacement 90,592 KM
09/22/2005 110451 ZSCT----Service Contracts N2355 - Switch - Multifunction (Instrument Panel) - Replace 90,592 KM
09/22/2005 110451 ZSCT----Service Contracts N2220 - Switch - Engine Oil Pressure Sender - Replace 90,592 KM
09/22/2005 110451 ZFAT----Field Action Recall V1380 - 05546 - Replace Fuel Filter 90,592 KM
08/05/2005 108671 ZSCT----Service Contracts C0183 - Front Side Door Window Regulator Replacement - Left Side 88,112 KM
08/05/2005 108671 ZSCT----Service Contracts C0182 - Front Side Door Window Regulator Replacement - Right Side 88,112 KM
08/05/2005 108671 ZFAT----Field Action Recall V1382 - 05037 - Stitch Seat Loop Closed 88,112 KM
02/14/2005 101468 ZREG----Regular Vehicle Transaction K5228 - Switch, Park/Neutral Position - Replace 76,630 KM
08/25/2004 094448 ZSCT----Service Contracts E7700 - Shaft, Steering Intermediate - Replace 66,582 KM
08/25/2004 094448 ZSCT----Service Contracts B5750 - Support, Tailgate/Endgate Cable - One Or Both - Replace 66,582 KM
05/18/2004 090212 ZREG----Regular Vehicle Transaction E8041 - Tie Rod, Inner - Left - Replace 57,974 KM
09/09/2003 221910 ZREG----Regular Vehicle Transaction J6354 - Powertrain Control Module Engine Reprogramming with SPS 38,523 KM
07/25/2003 218721 ZREG----Regular Vehicle Transaction J5860 - Turbocharger Replacement 34,363 KM
08/01/2002 A03251 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 KM
#1083
Vehicle Information
VIN: 2GTEK69U111315940 Model: TK15753-2001 GMC SIERRA 1500HD 4WD CREW CAB
Order Type: 70 - RETAIL - STOCK
Vehicle has no current record of required field actions.
Branded Title
Warranty Block
Service Information
Emission Select Component Ltd Wty 04/20/2001 101 MI 04/20/2009 80,101 MI
Corrosion Limited Warranty 04/20/2001 101 MI 04/20/2007 100,101 MI
Bumper to Bumper Limited Warranty 04/20/2001 101 MI 04/20/2004 36,101 MI
Service Contract
08/13/2004 072046 ZREG----Regular Vehicle Transaction B5750 - Support, Tailgate/Endgate Cable - One Or Both - Replace 87,425 MI
07/31/2001 072757 ZREG----Regular Vehicle Transaction Add Credit R2480 - Support, Front Bumper Fascia Lower - Replace 15,667 MI
07/31/2001 072757 ZREG----Regular Vehicle Transaction R2480 - Support, Front Bumper Fascia Lower - Replace 15,667 MI
07/16/2001 072381 ZREG----Regular Vehicle Transaction D1180 - Switch, Pressure Cycling - Replace 13,228 MI
03/06/2001 A15940 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
#1086
Thinking about buying this truck.. Can you run the vin for me?
2GCEC13YX71624679
2GCEC13YX71624679
Vehicle Information
VIN: 2GCEC13YX71624679 Model: CC10543-2007 SILVERADO 1500 2WD CREW CAB
Product Safety Recall N080048 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS 08/28/2008 Closed
Product Safety Recall N100153 10153 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - DISABLE AND REMOVE MODULE 06/08/2010 Closed
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: 3CHDR0MX XM Status: Inactive
Bumper to Bumper Limited Warranty 09/17/2007 6 MI 09/17/2010 36,006 MI
Corrosion Limited Warranty 09/17/2007 6 MI 09/17/2013 100,006 MI
Powertrain Limited Warranty 09/17/2007 6 MI 09/17/2012 100,006 MI
Emission Select Component Ltd Wty 09/17/2007 6 MI 09/17/2015 80,006 MI
Service Contract
07/31/2010 75626 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 38,428 MI
08/31/2009 105361 ZREG----Regular Vehicle Transaction K5365 - Transmission Control Module Replacement 35,150 MI
08/31/2009 105361 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 35,150 MI
06/01/2009 104295 ZREG----Regular Vehicle Transaction R4490 - Remote Control Door Lock Transmitter Replacement 33,398 MI
06/01/2009 104295 ZREG----Regular Vehicle Transaction J3175 - Line And/Or Hose, Engine Oil Cooler - Pipe Assembly - Replace 33,398 MI
03/16/2007 344649 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 3 MI
02/27/2007 A24679 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
#1087
Wow dude! I am amazed. Since this truck was purchased...it never wnet to the shop for any type of warranty service.
Vehicle Information
VIN: 2GCEC19K3M1212750 Model: -
Order Type: N/A
Branded Title
Warranty Block
Service Information
Vehicle has no current record of OnStar / XM Radio information.
Vehicle has no current record of applicable warranties.
Service Contract
06/14/2001 035458 ZFAT----Field Action Recall V7930 - 1988-93 C/K W/L03/L05/L19 & MD8/M30/M40 FLUID SYSTEM 172,082 MI
Vehicle Information
Order Type: N/A
Branded Title
Warranty Block
Service Information
Service Contract
#1090
i got a dmax im looking at: 1GCHK23215F961751 thanks
Here it is my man...enjoy...
Vehicle Information
VIN: 1GCHK23215F961751 Model: CK25743-2005 SILVERADO 2500HD 4WD CREW
Branded Title
Warranty Block
Service Information
OnStar Equipped: Y OnStar Status: Active
XM Equipped: Y XM Radio ID: R4EXA0WV XM Status: Active
OnStar Vehicle Diagnostics: Y DMN Enabled: N
Bumper to Bumper Limited Warranty 06/24/2005 483 MI 06/24/2008 36,483 MI
Diesel Engine Ltd Wty with Deductible 06/24/2005 483 MI 06/24/2010 100,483 MI
Corrosion Limited Warranty 06/24/2005 483 MI 06/24/2011 100,483 MI
Emission Limited Warranty 06/24/2005 483 MI 06/24/2010 50,483 MI
Service Contract
04/30/2009 443973 ZREG----Regular Vehicle Transaction Add Credit J3524 - Engine Coolant Heater Replacement 72,683 MI
04/30/2009 443973 ZREG----Regular Vehicle Transaction J3524 - Engine Coolant Heater Replacement 72,683 MI
04/20/2006 395188 ZREG----Regular Vehicle Transaction J0667 - Drive Belt Replacement - Accessory 19,544 MI
06/16/2005 380636 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 1 MI
06/06/2005 A61751 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
