Check Re-Calls & Service History Here
#1141
#1142
VIN: 1GTHK23D46F161383 Model: TK25743-2006 GMC SIERRA SLT 2500 CREW CAB 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Product Emission Recall N060522 06522 ENGINE GLOW PLUG SYSTEM CONCERN - REPROGRAM GLOW PLUG CONTROL MODULE 03/27/2006 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Vehicle has no current record of OnStar / XM Radio information.
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Certified Used Limited Warranty 01/28/2006 200 MI 04/28/2009 39,200 MI
Diesel Engine Ltd Wty with Deductible 01/28/2006 200 MI 01/28/2011 100,200 MI
Bumper to Bumper Limited Warranty 01/28/2006 200 MI 01/28/2009 36,200 MI
Emission Limited Warranty 01/28/2006 200 MI 01/28/2011 50,200 MI
Corrosion Limited Warranty 01/28/2006 200 MI 01/28/2012 100,200 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
08/20/2007 343068 ZREG----Regular Vehicle Transaction N9561 - HVAC Module Connector and Resistor - Replace 21,553 MI
05/10/2006 296129 ZFAT----Field Action Recall V1464 - 06522 - Reprogram Glow Plug Control Module 6,491 MI
02/06/2006 286503 ZREG----Regular Vehicle Transaction C3128 - Headlining Trim Panel Replacement 869 MI
02/06/2006 286503 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 869 MI
11/09/2005 A61383 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
#1144
Hi, when you have a chance can you run my VIN? I just bought this truck.
VIN # 1GCEC14V11Z212492
Thank you
Thank you
#1145
Torque Wrench,
Ive had this one for a while but might as well check it out.
2GTEK13T651149858
Thanks in advance
2GTEK13T651149858
Thanks in advance
#1147
Thank you
Thank you
Here you go friend!
Vehicle Information
VIN: 1GCEC14V11Z212492 Model: CC15703-2001 C1500 4X2
Product Safety Recall N040007 04007 TAILGATE SUPPORT CABLE 09/17/2004 Closed
Noncompliance Recall N010021 01021 CERTIFICATION & TIRE PRESSURE LABEL INFORMATION INCORRECT 05/24/2001 Closed
Branded Title
Warranty Block
Service Information
Emission Select Component Ltd Wty 08/22/2001 75 MI 08/22/2009 80,075 MI
Bumper to Bumper Limited Warranty 08/22/2001 75 MI 08/22/2004 36,075 MI
Emission Select State Component Lty Wty 08/22/2001 75 MI 08/22/2008 70,075 MI
Emission Limited Warranty 08/22/2001 75 MI 08/22/2004 50,075 MI
Corrosion Limited Warranty 08/22/2001 75 MI 08/22/2007 100,075 MI
Service Contract
03/02/2005 066642 ZFAT----Field Action Recall V1242 - 04007 - Inspect and Replace Tailgate Support Cables inc. Hinge Replacement if Necessary 28,656 MI
03/02/2005 066642 ZFAT----Field Action Recall V0690 - INSTALL LABEL 28,656 MI
05/30/2001 680967 ZREG----Regular Vehicle Transaction A5580 - Rail Dust Removal - Non Acid Products 25 MI
#1148
Torque Wrench,
2GTEK13T651149858
Thanks in advance
2GTEK13T651149858
Thanks in advance
Vehicle Information
VIN: 2GTEK13T651149858 Model: TK15543-2005 GMC SIERRA 1500 4WD CREW CAB
Vehicle has no current record of required field actions.
Branded Title
Warranty Block
Service Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677).
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: GCZG50HZ XM Status: Inactive
OnStar Vehicle Diagnostics: N DMN Enabled: N
Special Coverage-07187 12/31/2004 100 MI 12/31/2011 80,100 MI
Bumper to Bumper Limited Warranty 12/31/2004 100 MI 12/31/2007 36,100 MI
Certified Used Limited Warranty 12/31/2004 100 MI 03/31/2008 39,100 MI
Certified Used Powertrain Limited Wty 12/31/2004 100 MI 12/31/2009 100,100 MI
Emission Select Component Ltd Wty 12/31/2004 100 MI 12/31/2012 80,100 MI
Corrosion Limited Warranty 12/31/2004 100 MI 12/31/2010 100,100 MI
Service Contract
08/10/2007 392857 ZREG----Regular Vehicle Transaction D1811 - Temperature Valve Actuator Replacement - Right Side 31,343 MI
02/01/2006 188446 ZREG----Regular Vehicle Transaction Z7904 - 4-DAY COURTESY TRANSPORTATION 12,368 MI
01/24/2006 188128 ZREG----Regular Vehicle Transaction B4433 - Hinge, Rear Door (Weld On) - Body Side - Left Upper - Replace 12,363 MI
01/24/2006 188128 ZREG----Regular Vehicle Transaction H0042 - Pads, Disc Brake - Front - R&R Or Replace 12,363 MI
12/14/2005 189837 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 10,730 MI
12/14/2005 186568 ZREG----Regular Vehicle Transaction C6170 - Spring, Seat Adjuster - Bucket Seat - R&R Or Replace 10,730 MI
12/14/2005 186568 ZREG----Regular Vehicle Transaction C3201 - Panel, Center Pillar Trim Finishing - Left - R&R Or Replace 10,730 MI
12/14/2005 186568 ZREG----Regular Vehicle Transaction E7700 - Shaft, Steering Intermediate - Replace 10,730 MI
12/14/2005 186568 ZREG----Regular Vehicle Transaction J6354 - Powertrain Control Module Engine Reprogramming with SPS 10,730 MI
02/15/2005 135893 ZREG----Regular Vehicle Transaction C0182 - Front Side Door Window Regulator Replacement - Right Side 1,956 MI
02/15/2005 135893 ZREG----Regular Vehicle Transaction E0203 - Tire and Wheel Balancing - Four 1,956 MI
01/20/2005 134999 ZREG----Regular Vehicle Transaction E0203 - Tire and Wheel Balancing - Four 722 MI
09/09/2004 A49858 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
#1149
Here you Sir...this one has been a bit of a Garage Queen
