Check Re-Calls & Service History Here
#322
Hey bro...looks like you got the ONStar digital upgrade service bulletin that's still open...the other have been closed. Just some Intermediate Steering Shaft replacements..lol..we all got that though...
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 05037 SECOND ROW CENTER SAFETY BELT N/A Closed
SERVICE INFORMATIONAL ITEMS
SB 06047 ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. 02/21/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Active Refer to Help page for details or: http://www.onstarenrollment.com or (888)ONSTAR1 (888)667-8271. In Canada, http://onstar.enrollment.ca or (877)438-9677.
XM Equipped Yes XM Radio ID YV7Q20H9 XM Status Active Refer to Help page for details or: http://www.gm.xmradio.com or (800)556-3600. In Canada, http:// xmradio.ca or (877)438-9677.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 11/17/2003 117 miles 11/17/2006 36117 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH 11/17/2003 117 miles 11/17/2009 100117 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 11/17/2003 117 miles 11/17/2011 80117 miles
36/50000 CALIFORNIA EMISSIONS 11/17/2003 117 miles 11/17/2006 50117 miles
84/70000 CALIFORNIA SELECT COMPONENT 11/17/2003 117 miles 11/17/2010 70117 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
05/14/2007 008496 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 58000 miles
09/17/2006 G33718 # Z8020 - ONSTAR - TOW 53000 miles
07/12/2006 239794 # V1382 - 05037 - STITCH SEAT LOOP CLOSED 49540 miles
09/16/2003 A35936 G Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
09/16/2003 A35936 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
CLAIM HISTORY
can you tell if mine has had the brake resevoir recall done? something to do with a valve in the resevoir. says if its hard to steer when trying to park and some other stuff. i ask because when going into park spots some times it feels like my power steering just goes away then comes back. incase you need it again 1GENK13T24J135936
#323
4.8T it dosen't show to have had that repair done. You may call you local consultant and see if they are having problems with any others with the same complaint.
#324
ok thanks, its an actual recall. i'll check what year and models though.
found it recall number 04V045000
Vehicle: 2004 Chevrolet Tahoe
Defect Description:
CERTAIN SPORT UTILITY VEHICLES, PICKUP TRUCKS, AND PASSENGER VANS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 135, ?PASSENGER CAR BRAKE SYSTEMS.? SOME OF THESE VEHICLES WERE PRODUCED WITH AN OUT-OF-SPECIFICATION BRAKE HYDRO-BOOST HOUSING RELIEF VALVE BORE.
Consequence of Defect:
CONSEQUENTLY, THE VALVE O-RING SEAL MAY FRACTURE. STEERING EFFORTS MAY BE SLIGHTLY INCREASED WHILE BRAKING OR PARKING. UNDER CERTAIN DRIVING CONDITIONS, A FRACTURED SEAL MAY REQUIRE A SLIGHT INCREASE IN THE APPLIED BRAKE PEDAL EFFORT TO ACHIEVE THE SAME VEHICLE DECELERATION RATE AS PRIOR TO THE SEAT FRACTURE.
Corrective Action:
DEALERS ARE TO REPLACE THE HYDRO-BOOST RELIEF VALVE. THE RECALL BEGAN ON JUNE 18, 2004. OWNERS SHOULD CONTACT CADILLAC AT 1-866-982-2339; CHEVROLET AT 1-800-630-2438; GMC AT 1-866-996-9463; OR HUMMER AT 1-866-486-6376.
Defect Description:
Corrective Action:
#328
#329
#330
Vehicle Has No Current Record Of Outstanding Service Information
Vehicle Has No Associated On Star or XM Radio Information.
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 06/14/2004 5 miles 06/14/2007 36005 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 06/14/2004 5 miles 06/14/2010 100005 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 06/14/2004 5 miles 06/14/2012 80005 miles
36/36000 FEDERAL EMISSION 06/14/2004 5 miles 06/14/2007 36005 miles
CLAIM HISTORY
09/07/2006 185891 # E3807 - SHOCK ABSORBER, FRONT - BOTH - REPLACE 34335 miles
09/07/2006 185891 # E1730 - CROSSMEMBER, FRONT SUSPENSION - REPLACE 34335 miles
09/07/2006 185891 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 34335 miles
09/07/2006 185891 # C2684 - LENS, LAMP INTERIOR AND/OR REAR COMPARTMENT - REPLACE 34335 miles
09/07/2006 185891 # C6510 - ACTUATOR, FRONT SEAT BACK (MANUAL RECLINING OR RELEASE UNI 34335 miles
07/03/2006 180099 # D1002 - BLOWER MOTOR RESISTOR REPLACEMENT 30767 miles
02/24/2006 168469 # N0851 - BULB, FOG LAMP (LEFT) - REPLACE 24416 miles
02/24/2006 168469 # V1382 - 05037 - STITCH SEAT LOOP CLOSED 24416 miles
08/16/2004 500419 # R0760 - RADIO, REMOVE AND REPLACE 3231 miles
05/17/2004 A99274 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Pretty clean looking to me.
