Check Re-Calls & Service History Here
#31
#32
Originally Posted by Sierra1sh
Hey Jerry...you lucked out...you got no open re-calls so I've posted your service history below. Hope this helps out. Thanx-- Torque
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/28/2006 373581 # C3161 - PANEL, BODY LOCK PILLAR TRIM FINISH - LOWER - LEFT - R&R O 16113 miles
06/28/2006 373581 # R4490 - TRANSMITTER, REMOTE DOOR/REAR COMPARTMENT LOCK - REPLACE 16113 miles
11/15/2005 353966 # C9040 - BELT, SEATBELT RETRACTOR (FRONT) (RIGHT) - REPLACE 11838 miles
02/16/2005 329828 # K7271 - BAND, 2-4 - R&R OR REPLACE 9631 miles
12/27/2004 326122 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 6501 miles
12/07/2004 324824 # K7252 - CLUTCH, 3-4 - R&R OR REPLACE 6468 miles
12/07/2004 324824 # Z7902 - 2-DAY COURTESY TRANSPORTATION 6468 miles
12/22/2003 A30353 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
#34
PT's Slowest Truck
Okie dokie TW, pretty sure that I'm up to date, but what the heck...here's my vin: 1GCEK14T4XZ107374
My history should show a bunch of little junk done under warranty, and a few recalls through the years.
Thanx brother!
Thanx brother!
#35
Thanx brother!
Thanx brother!
SORRY IM SURE TORQUE WRENCH WENT HOME FOR THE DAY... AND IM BORED!!!
04/10/2006 179141 # V0486 - 1999-00 CV & GMC C/K 1/2T P/U - INSTALL NOTICE LABEL 46906 miles
04/10/2006 179141 # V1411 - 05068 - INSPECT AND REPLACE ONE OR BOTH WHEEL SPEED SENSOR 46906 miles
04/10/2006 179141 # V1462 - 06019 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 46906 miles
05/15/2003 122461 # H2505 - MODULE, ELECTRONIC BRAKE AND/OR TRACTION CONTROL - FOUR WH 30744 miles
05/15/2003 122461 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 30744 miles
02/05/2002 098080 # R0750 - RECEIVER, RADIO - REMOVE AND REPLACE RADIO - RETURN TO AC- 21085 miles
12/31/2001 095981 # E3807 - SHOCK ABSORBER, FRONT - BOTH - REPLACE 20180 miles
08/15/2001 088385 # D1445 - DEFLECTOR, AIR (OUTLET VENT) - LEFT SIDE GLASS - REPLACE 19100 miles
07/26/2001 087153 # J6372 - SENSOR, OXYGEN (ENGINE CONTROL) - REPLACE 19015 miles
05/29/2001 161655 # E3807 - SHOCK ABSORBER, FRONT - BOTH - REPLACE 17841 miles
05/29/2001 161655 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 17841 miles
05/03/2001 160038 # F1280 - PROPELLER SHAFT ASSEMBLY (BETWEEN TRANS AND REAR DIFFERENT 17300 miles
05/03/2001 160038 # V0523 - REPLACE DRIVERS & PASS SEAT BELT RETRACTORS 17300 miles
05/03/2001 160038 # E5137 - SPRING ASSEMBLY, REAR LEAF - BOTH - REPLACE 17300 miles
05/03/2001 160038 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 17300 miles
05/03/2001 160038 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - REPLACE 17300 miles
02/20/2001 155555 # K4290 - PLUG, TRANSFER CASE DRAIN - REPLACE 15691 miles
02/20/2001 155555 # J0690 - PULLEY, ACCESSORY DRIVE BELT IDLER - REPLACE 15691 miles
02/20/2001 155555 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 15691 miles
11/30/2000 150481 # C0687 - GLASS, BACK WINDOW SLIDING - COMPLETE - REPLACE 13944 miles
10/02/2000 146564 # C0687 - GLASS, BACK WINDOW SLIDING - COMPLETE - REPLACE 12512 miles
10/02/2000 146564 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 12512 miles
10/02/2000 146564 # J5490 - BODY UNIT, THROTTLE - REPLACE 12512 miles
10/02/2000 146564 # T5999 - ADDITIONAL PART MARKUP PERCENTAGE OVER 40% NORM 12512 miles
10/06/1999 052451 # C0687 - GLASS, BACK WINDOW SLIDING - COMPLETE - REPLACE 5605 miles
09/20/1999 051614 # C0670 - R/R WIN GLASS RES 5002 miles
11/06/1998 A07374 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
#36
Hey Budhayes....lol....dang brother....you're service history on your truck looks like mine! lol....I got a service history list as long as my leg......and keep in mind I'm 6'3....so that's a long list!
#37
PT's Slowest Truck
LOL, yea, I guess that's what happens when you buy the first year of a new model...the dealers didn't seem to mind when I came in though...I always diagnosed the problems for them first, let them take their time and hold the truck over night if they had to, and then gave them 100% Completely Satisfied on the survey
Thanks CHEVYRACER83
Thanks CHEVYRACER83
#38
GOD THE SURVEY!!!! I HATE THE SONG AND DANCE THE SERVICE COSULTANTS HAVE TO DO OUT HERE TO GET THESE CHEAP BASTARDS TO BRING IN OR FILL OUT THEIR SURVEY..... THEN HOPE THEY DONT SLAM US JUST TO BE ******
#40
THINK YOURS IS BAD.... HERES MINE
WORKING AT A DEALER I GET ALOT OF CRAP DONE...
ADD INTERMITTENT TRANS PROBLEM TO THE LIST TODAY....
I DONT HAVE A TRANS PROBLEM... BUT IM GETTING IT WRITEN UP SO MY TRANS GUY CAN FLAG SOME TIME FOR PUTTING IN MY BILLET SERVOS, AND MY TRANSGO SPACER PLATE..... ALL COURTESY OF FLT!!!!
EDIT: IF YOU LOOK CLOSELY ONE OF MY TECHS FLAGGED A FUEL FILTER CHANGE.... YET MY TRUCK DOESNT HAVE A FUEL FILTER
I LAUGHED MY *** OFF WHEN I SAW THAT
04/30/2007 528328 # D3082 - HOSES AND/OR LINES, REFRIGERANT - COMPRESSOR DISCHARGE - R 20570 miles
04/19/2007 527436 # E9050 - PUMP ASSEMBLY, POWER STEERING - REPLACE 19651 miles
04/13/2007 527191 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 19451 miles
04/13/2007 527191 # E7012 - SWITCH AND/OR CONTROL, STEERING WHEEL MOUNTED - REPLACE 19451 miles
04/02/2007 526245 # H0042 - PADS, DISC BRAKE - FRONT - R&R OR REPLACE 18552 miles
02/08/2007 522152 # J9991 - CUSTOMER CONCERN NOT DUPLICATED 14266 miles
01/03/2007 519321 # J0990 - PLUG AND/OR GASKET, OIL PAN DRAIN - REPLACE 11638 miles
12/20/2006 518425 # J5420 - FILTER, FUEL ELEMENT - REPLACE 10733 miles
12/20/2006 518425 # J9995 - CUSTOMER CONCERN NOT DUPLICATED 10733 miles
03/24/2006 A71257 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
