Check Re-Calls & Service History Here
Old 04-14-2008, 07:13 AM
  #411
Originally Posted by 4ws f 7
1GCGK13U95F875711
Like already stated thanks! I have a couple of questions.
I bought this used, dealer stated it was a G.M. executive car, some manufacturers have demo's that warr. doesn't start till sold to a customer, is this true?
Also it has Quadrasteer and right side bed has pieces missing from front and back corners like the bed flexed and chipped these corners of bed, is there a recall or bulletin?
Thanks again!
Yes you are correct about the Demo clause with the warrany. But the pieces missing form the bed is no recall....it sounds like you should have asked them to repair that before buying it. Below is your Info.
VEHICLE INFORMATION
Merchandising Model : CK15743 -2005 SILVERADO 1500HD 4WD CREW CAB Warranty Start Date : 01/07/2005
BARS Order Type : 81 - DEALER USED CAR (CVMS USE)
Delivering Dealer : N/A Selling Source : N/A
Site Code : N/A
Business Associate Code : N/A
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Type Number Description Posted Date Status
SB 06049 ONSTAR H/W IS DIGITAL-CAPABLE. NO UPGRADE IS NEEDED. SEE TSB 06-08-46-008. 02/22/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID 9E8780MG XM Status Active Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 01/07/2005 0 miles 01/07/2008 36000 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 01/07/2005 0 miles 01/07/2011 100000 miles
39/39000 GM CERTIFIED USED LIMITED WARRANTY 01/07/2005 0 miles 04/07/2008 39000 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 01/07/2005 0 miles 01/07/2013 80000 miles
60/50000 FEDERAL EMISSION 01/07/2005 0 miles 01/07/2010 50000 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
12/28/2004 100808 I Z6998 - PDI ADDS 6 miles
12/28/2004 100808 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 6 miles
Torque_Wrench is offline
Old 04-14-2008, 03:31 PM
  #412
sierraperformance's Avatar
VIN# 2GTEC19N541345861
2004 SIERRA VHO
Thanks,
John
sierraperformance is offline
Old 04-15-2008, 08:47 AM
  #413
2004 SIERRA VHO
Thanks,
John
Got a bit of a lenghty service history, but it's none out of the ordinary. Here ya go friend.
VEHICLE INFORMATION
Merchandising Model : TC15753 -2004 SIERRA 1500 2WD 4 DOOR PICKUP Warranty Start Date : 05/05/2004
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : GRAYSON MOTORS OF TEXAS, INC.
PO BOX 1145
SHERMAN , TX 75091-1145
(903) 892-1561
Selling Source : 48 - GMC TRUCK
Site Code : 08062
Business Associate Code : 160165
Vehicle Has No Current Record Of Outstanding Service Information
Vehicle Has No Associated On Star or XM Radio Information.
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 05/05/2004 58 miles 05/05/2007 36058 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/05/2004 58 miles 05/05/2010 100058 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/05/2004 58 miles 05/05/2012 80058 miles
36/36000 FEDERAL EMISSION 05/05/2004 58 miles 05/05/2007 36058 miles
CLAIM HISTORY
07/17/2007 234565 # R0760 - RADIO, REMOVE AND REPLACE 39039 miles
04/10/2007 231425 # R0760 - RADIO, REMOVE AND REPLACE 35996 miles
04/06/2007 231316 # F0060 - SLIP JOINT, PROPELLER SHAFT (BETWEEN TRANS AND REAR DIFFER 35860 miles
04/06/2007 231316 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 35860 miles
10/05/2006 224270 # D1812 - ACTUATOR AND/OR MOTOR, ELECTRIC - TEMPERATURE DOOR - LEFT 30980 miles
10/05/2006 224270 # N1736 - BLOCK ASSEMBLY, WIRING HARNESS JUNCTION - LEFT BODY AND IN 30980 miles
10/05/2006 224270 # D1811 - ACTUATOR AND/OR MOTOR, ELECTRIC - TEMPERATURE DOOR - RIGHT 30980 miles
10/05/2006 224270 # C3540 - REAR SIDE DOOR TRIM PANEL REPLACEMENT - RIGHT SIDE 30980 miles
10/05/2006 224270 # Z7903 - 3-DAY COURTESY TRANSPORTATION 30980 miles
04/25/2006 218158 # C0511 - GLASS, QUARTER STATIONARY - LEFT - R&R OR REPLACE 25827 miles
04/25/2006 218158 # C0510 - GLASS, QUARTER STATIONARY - RIGHT - R&R OR REPLACE 25827 miles
04/25/2006 218158 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 25827 miles
03/14/2005 202620 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 12307 miles
08/09/2004 193636 # E3531 - ARM ASSEMBLY, FRONT CONTROL - LOWER - LEFT - REPLACE 3819 miles
07/09/2004 192239 # A9976 - POP/NOISE, FRAME RAIL - REPAIR 2648 miles
07/09/2004 192239 # E2020 - WHEEL ALIGNMENT - CHECK AND/OR ADJUST 2648 miles
07/09/2004 192239 # H2881 - PARKING BRAKE REAR CABLE REPLACEMENT - LEFT SIDE 2648 miles
03/29/2004 A45861 G Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
03/29/2004 A45861 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old 04-15-2008, 11:20 AM
  #414
Thumbs up
Thanks for the reply. You did an awesome job on it.
Old 04-15-2008, 01:22 PM
  #415
Thank you sir....
Old 04-15-2008, 01:32 PM
  #416
Moderately Differentiated
dewmanshu's Avatar
Amazing...thanks Torque!
dewmanshu is offline
Old 04-15-2008, 02:43 PM
  #417
Red03SilSS's Avatar
2GCEK19N231346497
2003 Silverado SS
TIA
Daniel
Red03SilSS is offline
Old 04-15-2008, 02:54 PM
  #418
Rays B4U's Avatar
Thumbs up
Originally Posted by Torque_Wrench
Hey Ray,
You don't too bad at all here. I see you got a new Steering Shaft as the last covered Op. So you should be good for awhile. Here's your history.
VEHICLE INFORMATION
Merchandising Model : CK15753 -2003 SILVERADO SS 1500 4WD EXT CAB Warranty Start Date : 04/23/2003
Delivering Dealer : CASCADE AUTO CENTER
PO BOX 2987
WENATCHEE , WA 98807-2987
(509) 663-0011
Selling Source : 13 - CHEVROLET
Site Code : 19078
Business Associate Code : 114518
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 04/23/2003 57 miles 04/23/2006 36057 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 04/23/2003 57 miles 04/23/2009 100057 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 04/23/2003 57 miles 04/23/2011 80057 miles
36/36000 FEDERAL EMISSION 04/23/2003 57 miles 04/23/2006 36057 miles
CLAIM HISTORY
09/28/2007 355571 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 37884 miles
06/23/2006 345286 # N0912 - SOCKET, LAMP - EXTERIOR - REPLACE 29085 miles
03/28/2005 334758 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 23148 miles
03/28/2005 334758 # K9995 - CUSTOMER CONCERN NOT DUPLICATED 23148 miles
03/28/2005 334758 # F9995 - CUSTOMER CONCERN NOT DUPLICATED 23148 miles
03/21/2005 334595 # H0087 - CALIPER ASSEMBLY - FRONT - BOTH - R&R 23110 miles
03/21/2005 334595 # C3200 - PANEL, CENTER PILLAR TRIM FINISHING - RIGHT - R&R OR REPLA 23110 miles
03/21/2005 334595 # C0314 - REAR SIDE DOOR WINDOW REPLACEMENT - RIGHT SIDE 23110 miles
03/21/2005 334595 # Z7901 - 1-DAY COURTESY TRANSPORTATION 23110 miles
05/10/2004 326710 # C0511 - GLASS, QUARTER STATIONARY - LEFT - R&R OR REPLACE 12253 miles
05/10/2004 326710 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 12253 miles
03/13/2003 A19347 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Torque_Wrench,
Thanks for your help on this, I used the info for a $1600 battle with my local service dept and WON!
Ray
Rays B4U is offline
Old 04-15-2008, 03:21 PM
  #419
dewmanshu's Avatar
Originally Posted by Rays B4U
Torque_Wrench,
Ray
Old 04-15-2008, 06:41 PM
  #420
4ws f 7's Avatar
VEHICLE INFORMATION
Site Code : N/A
CLAIM HISTORY
Would a G.M. executive car automatically have a delayed warranty like a dealer demo? Is there something I can or need to do to reinstate warranty? I didn't notice the bed issue for 2-3 weeks after I bought it, so I was not 100% sure when it actually happened.
Thanks again for the info.
4ws f 7 is offline
Quick Reply: Check Re-Calls & Service History Here
