Check Re-Calls & Service History Here
Old 05-16-2008, 03:20 PM
  #461
Originally Posted by 1BADAZZSS
So does that mean the engine has been replaced?
No actually, you just had all lifters replaced, which is kinda common but not...if you know what I mean. I've seen numerous lifter replacements and camshaft rplacements.
Torque_Wrench is offline
Old 05-17-2008, 12:07 PM
  #462
jake 03's Avatar
hey can you check mine out,got it used.
vin 2GECK19T531166347
thanks
jake 03 is offline
Old 05-18-2008, 11:44 AM
  #463
dhpro's Avatar
Thnx a ton! Gonna try to get the GatorBACK vinyl recoating done now...I dont anticipoate any probs, but they said they thot the bulletin was expired...can u verify yes or no? Last, the rust sheet metal perforation, does that cover rsut formations on the bottom inside of doors - wher the skin seam is on the bottom sill? R/
Originally Posted by Torque_Wrench
No problem, here you go friend...
You have a lenghty service history but it's mainle because it seems there was a GM Maintenance plan on this vehicle.
VEHICLE INFORMATION
Merchandising Model : CK15936 -2004 AVALANCHE 1500 4WD Warranty Start Date : 10/03/2003
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : THE KARL CHEVROLET COMPANY
PO BOX 1146
NEW CANAAN , CT 06840-1146
(203) 966-9508
Selling Source : 13 - CHEVROLET
Site Code : 02289
Business Associate Code : 111148
Service Contract : Yes Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
RC 05037 SECOND ROW CENTER SAFETY BELT N/A Closed
SERVICE INFORMATIONAL ITEMS
SB 06047 ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. 02/21/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID 03BU204R XM Status Active Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 10/03/2003 0 miles 10/03/2006 36000 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 10/03/2003 0 miles 10/03/2009 100000 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 10/03/2003 0 miles 10/03/2011 80000 miles
36/50000 CALIFORNIA EMISSIONS 10/03/2003 0 miles 10/03/2006 50000 miles
84/70000 CALIFORNIA SELECT COMPONENT 10/03/2003 0 miles 10/03/2010 70000 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
03/13/2008 120254 0 E8040 - TIE ROD, INNER - RIGHT - REPLACE 44919 miles
03/13/2008 120254 # B5795 - BEZEL, TAILGATE/ENDGATE OUTSIDE HANDLE - REPLACE 44919 miles
03/13/2008 120254 0 E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 44919 miles
03/13/2008 120254 0 E8041 - TIE ROD, INNER - LEFT - REPLACE 44919 miles
02/06/2007 149754 0 B5830 - LATCH, TAILGATE/ENDGATE - RIGHT - R&R OR REPLACE 38719 miles
02/06/2007 149754 0 B5831 - LATCH, TAILGATE/ENDGATE - LEFT - R&R OR REPLACE 38719 miles
02/06/2007 149754 0 N4180 - INSTRUMENT CLUSTER REPLACEMENT 38719 miles
01/17/2007 149096 0 B5800 - ENDGATE HANDLE REPLACEMENT 38077 miles
12/22/2006 148396 0 E2321 - BEARING AND HUB ASSEMBLY, FRONT WHEEL - LEFT - REPLACE 37212 miles
12/22/2006 148396 0 B5939 - STRIKER, LIFTGATE/ENDGATE/TAILGATE - ADJUST OR REPLACE 37212 miles
09/22/2006 145573 0 M0017 - LUBE, OIL AND FILTER 34553 miles
09/22/2006 145573 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 34553 miles
05/26/2006 141729 0 M0017 - LUBE, OIL AND FILTER 29069 miles
05/26/2006 141729 # N6644 - WIRING AND/OR CONNECTOR - MIRROR SYSTEM - REPAIR OR REPLAC 29069 miles
05/26/2006 141729 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 29069 miles
01/19/2006 137522 0 M0017 - LUBE, OIL AND FILTER 24363 miles
01/19/2006 137522 # B4150 - OUTSIDE REARVIEW MIRROR GLASS REPLACEMENT - RIGHT SIDE 24363 miles
10/06/2005 133652 0 M0017 - LUBE, OIL AND FILTER 20650 miles
10/06/2005 133652 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 20650 miles
10/06/2005 133652 # V1382 - 05037 - STITCH SEAT LOOP CLOSED 20650 miles
09/04/2005 726010 # Z2080 - ROADSIDE SERVICE (TOWING) 19000 miles
06/14/2005 129406 0 M0017 - LUBE, OIL AND FILTER 17305 miles
01/06/2005 230344 0 M0015 - LUBE, OIL AND FILTER 13581 miles
10/15/2004 120468 0 M0017 - LUBE, OIL AND FILTER 11785 miles
10/15/2004 120468 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 11785 miles
10/15/2004 120468 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 11785 miles
08/06/2004 222093 0 M0015 - LUBE, OIL AND FILTER 7850 miles
08/06/2004 222093 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 7850 miles
05/10/2004 114362 0 M0017 - LUBE, OIL AND FILTER 4560 miles
05/10/2004 114362 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 4560 miles
01/12/2004 109953 0 M0017 - LUBE, OIL AND FILTER 1413 miles
01/12/2004 109953 # B1784 - ARM, WIPER - WINDSHIELD (ONE OR BOTH) - REPLACE 1413 miles
10/16/2003 106754 # Z6999 - PDI RELATED FLUID ADDS 8 miles
09/25/2003 A39040 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
dhpro is offline
Old 05-18-2008, 12:00 PM
  #464
04Denali's Avatar
Hell, Might as run mine also, Thanks Guys you are doing a great service for us,
2GTFK69U041335332
Thanks,
Mark
04Denali is offline
Old 05-19-2008, 10:27 AM
  #465
2GTFK69U041335332
Thanks,
Mark
Hey bro, your thanx is appreciated....
Your vin has a lenghty service history on it but otherwise dosen't look out of the ordinary. Except it seems that you've had some paint issues with one entire body side?
VEHICLE INFORMATION
Merchandising Model : TK15753 -2004 SIERRA DENALI AWD 4 DR PICKUP Warranty Start Date : 04/12/2004
Delivering Dealer : PLUMMER PONTIAC CADILLAC GMC BUICK
1333 E KETTLEMAN LN
LODI , CA 95240-9765
(209) 369-3573
Selling Source : 48 - GMC TRUCK
Site Code : 40580
Business Associate Code : 116691
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
Vehicle Has No Current Record Of Outstanding Campaigns
SB 06049 ONSTAR H/W IS DIGITAL-CAPABLE. NO UPGRADE IS NEEDED. SEE TSB 06-08-46-008. 04/23/2007 See Bulletin
OnStar Equipped Yes OnStar Status Active Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID LR2E400R XM Status Active Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 04/12/2004 4 miles 04/12/2007 36004 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 04/12/2004 4 miles 04/12/2010 100004 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 04/12/2004 4 miles 04/12/2012 80004 miles
36/50000 CALIFORNIA EMISSIONS 04/12/2004 4 miles 04/12/2007 50004 miles
84/70000 CALIFORNIA SELECT COMPONENT 04/12/2004 4 miles 04/12/2011 70004 miles
CLAIM HISTORY
04/17/2007 132804 # R9350 - TONNEAU COVER 25151 miles
04/10/2007 132493 # Z2097 - ON-STAR ANALOG-TO-DIGITAL UPGRADE KIT - RETURN TO ACDELCO 25148 miles
04/09/2007 132491 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 25148 miles
04/09/2007 132491 # R0760 - RADIO, REMOVE AND REPLACE 25148 miles
04/09/2007 132491 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 25148 miles
04/09/2007 132491 # C2323 - INSTRUMENT PANEL LOWER TRIM PLATE REPLACEMENT 25148 miles
04/09/2007 132493 # Z2096 - ONSTAR ANALOG-TO-DIGITAL UPGRADE KIT - INSTALL 25148 miles
02/21/2007 130406 # B8235 - MOLDING/CAP, BED RAIL - RIGHT - REPLACE 21925 miles
02/21/2007 130406 # B8236 - MOLDING/CAP, BED RAIL - LEFT - REPLACE 21925 miles
02/21/2007 130406 # A5420 - BODY, ENTIRE BELOW BODY SIDE MOLDING - COLOR/CLEAR COAT 21925 miles
11/06/2006 126251 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 21925 miles
08/08/2005 105807 # C2140 - INSTRUMENT PANEL COMPARTMENT DOOR REPLACEMENT 7677 miles
07/25/2005 105050 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 7102 miles
07/21/2005 104939 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 6905 miles
02/01/2005 097131 # N0110 - BATTERY - ONE - REPLACE 4171 miles
05/18/2004 086793 # N0365 - DAYTIME RUNNING LAMP (DRL) AMBIENT LIGHT SENSOR REPLACEMEN 1258 miles
05/18/2004 086793 S Z7091 - NON-WARRANTY INCREMENTAL EXPENSE/WHOLESALE 1258 miles
05/18/2004 086793 # N6624 - WIRING AND/OR CONNECTOR - OCCUPANT SAFETY - REPAIR OR REPL 1258 miles
05/06/2004 086413 # N1720 - FUSE - REPLACE 740 miles
04/08/2004 085404 I Z6999 - PDI RELATED FLUID ADDS 11 miles
03/18/2004 A35332 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old 05-19-2008, 10:32 AM
  #466
thanks
hey friend, yours looks pretty good. No open re-calls, and not a bad service history at all.
VEHICLE INFORMATION
Merchandising Model : CK15753 -2003 SILVERADO LS 1500 4WD EXT CAB Warranty Start Date : 12/19/2002
Delivering Dealer : KORF CHEVROLET BUICK OLDS, INC.
PO BOX 130
YUMA , CO 80759-0130
(970) 848-5361
Site Code : 10507
Business Associate Code : 113014
Vehicle Has No Current Record Of Outstanding Service Information
Vehicle Has No Associated On Star or XM Radio Information.
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 12/19/2002 146 miles 12/19/2005 36146 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 12/19/2002 146 miles 12/19/2008 100146 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 12/19/2002 146 miles 12/19/2010 80146 miles
36/36000 FEDERAL EMISSION 12/19/2002 146 miles 12/19/2005 36146 miles
CLAIM HISTORY
03/14/2005 027262 B B4521 - REAR SIDE DOOR OUTSIDE HANDLE REPLACEMENT - LEFT SIDE 56499 miles
12/03/2004 045164 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 48272 miles
10/29/2004 039261 # E0600 - HOLD-DOWN, SPARE TIRE - R&R OR REPLACE 48222 miles
10/18/2004 025492 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 48550 miles
01/08/2004 021829 # N0528 - BULBS, LAMP - EXTERIOR - REPLACE 28050 miles
10/02/2002 026195 # Z6999 - PDI RELATED FLUID ADDS 5 miles
09/26/2002 A66347 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old 05-19-2008, 12:44 PM
  #467
jake 03's Avatar
thanks man,thats good news
jake 03 is offline
Old 05-19-2008, 12:49 PM
  #468
04Denali's Avatar
VEHICLE INFORMATION
1333 E KETTLEMAN LN
(209) 369-3573
Site Code : 40580
CLAIM HISTORY
while in texas someone tried to break into my truck and messed up the drivers side lock and they painted most of the side, my Dealership is great, any little thing I mention to them they would fix, like if the wood trim got scatched they would replace it for me under warranty.
thanks for looking it up for me.
Mark
04Denali is offline
Old 05-21-2008, 08:55 PM
  #469
magoo's Avatar
2006 GMC 1GTEK14V46Z257839
I'm curious what has been written up about my truck. I am currently arguing with the warranty dept. about some of the charges I had to pay. Thanks for any info.
magoo is offline
Old 05-25-2008, 11:24 AM
  #470
j225's Avatar
heres mine 3GCEC13J17G500956
just had it at the dealer friday,but theres not much wrong with it,i'm just tripping apparently
j225 is offline
Quick Reply: Check Re-Calls & Service History Here
